Old 02-15-2010, 05:10 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
solid CEL or blinking CEL?
40 psi fuel pressure seems a little low if that was under load.
working out the kinks, that's a good thing. Streets are fun in a Yaris.
Yeah I've had a blinking light before on a track day. Checked the code and found a cyl 2 misfire. But I think it was caused by too much limiter under part throttle.
I was told by one of my buddies from Toyota Canada that the flashing light indicated a lean condition and the Cat could potentially be damaged (melted).
Old 02-15-2010, 05:17 PM   #2
Jason@SportsCar
We don't have one.
Old 02-15-2010, 05:55 PM   #3
Bluevitz-rs
Originally Posted by Jason@SportsCar View Post
We don't have one.
Then are you running a different ECU? Or have you modified the signal going to the ECU to make it think there's a cat?
Because if the cat has been taken out with a stock computer, it'll set a code every time.
Old 02-15-2010, 06:13 PM   #4
Jason@SportsCar
That would be a different code.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
