Old 02-15-2010, 08:44 PM   #1
It's just a simple float switch that brings the line to ground when the level is low. I would bet that they installed the switch in upside down. It's not keyed to only be installed in one direction and it just has a tiny "V Down V" molded into one side of the lip.
Old 02-15-2010, 08:47 PM   #2
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
That just makes me laugh...I guess ill check it out when I get the time, they also put the wrong pump on the rear fluid hose and busted the hose inside the headliner>.<
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Tags
washer fluid light
SRS warning light - any guesses? Goose DIY / Maintenance / Service 15 03-24-2014 01:57 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Washer fluid "2.3 Full" stran General Yaris / Vitz Discussion 1 11-02-2009 09:19 PM
Low washer fluid light auxmike DIY / Maintenance / Service 3 12-14-2008 01:47 AM
