Old 02-18-2010, 02:21 PM   #1
They would be fine. If you want them to be switched with the dome and to fade like the dome, see this post from a prior thread:
http://www.yarisworld.com/forums/sho...0&postcount=14
You would tie the (+) lead of the LED strips to the blue wire and the (-) lead to the pink wire.
Old 02-18-2010, 11:25 PM   #2
Ah, the master mind. So, it should not be an issue if I just splice into those wires accordingly? talnlnky has me worried. I don't want to mess up/total my car. hehehe. THANKS!
Old 02-19-2010, 07:51 AM   #3
It's definitely safe to do. The dome light protected by a 10A fuse.
If you wanted to be super safe, you would add a fuse between your tap point and the LED strings that is appropriately rated for the current draw of the LEDs and the current carrying capacity of the wires that feed them. 24 AWG wire (which would be typically the smallest wire size for the leads of strips like those) is rated for 2.1A enclosed or 3.5A free-air. The LED strips would draw less than 0.25A per strip, so you could add a 2A inline fuse and be safe for the wire size. The 2A fuse would allow you to connect up to 8 of the strips.
When you have a huge discrepancy, like tapping a 50A fused circuit with 24 AWG wire, is where you really run into the issue that talnlnky is talking about. In that case, if you shorted your 24 AWG wires, the 50A fuse would need to pop, but the 24 AWG wires aren't rated for anywhere near 50A, so they would fail before the fuse, potentially catastrophically (i.e. fire).
Old 02-19-2010, 04:31 PM   #4
Another question for you. I'd like to run two of those LED strips, one for the driver side and one for the passenger side. How would I go about doing so? Is there a splice connector that I can buy to do that? I've never done installs like this before (only just replacing). All help is very much appreciated.
Old 02-19-2010, 04:44 PM   #5
You would connect the two strips in parallel (i.e. positive wire to positive wire and ground wire to ground wire). You could then tap the dome wires using tap splices (pictured below). Even though this is pretty simple, if you have never messed with this kind of thing before, it's not a bad idea to have someone who has give you a hand.
Old 02-19-2010, 04:49 PM   #6
I'm not sure if I'm getting this right. Okay, so, with the passenger side one, I should splice it's positive into the positive of the driver side one, and the same with the ground? Then with the driver side wires, splice into the blue and pink wires accordingly? Hehe, I kinda don't want to call my friend over for a "simple" job like this since I don't want to take up his time and gas. hehehehe. Well, actually, I'll probably do this at a car meet and have one of my friends oversee what I'm doing. hehehehe.
So, I should order at least 4 of those tap/splice connectors? They're sold in pairs on v-leds.
Old 02-19-2010, 05:00 PM   #7
You have it correct.
The splice connectors from v-leds are rated for 18-16AWG wire (which is correct for the car's wires that you are tapping onto). If the led strips have leads in that same size range, then you are OK. If they are smaller (24 - 20 AWG), then you would want tap splices that accommodate both (22 - 18 AWG for example). Auto parts stores typically carry a variety of tap splices.
