Old 02-19-2010, 01:02 AM   #1
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It could be the wear indicator. You need to get them checked. If the brakes get too worn, they'll damage the rotor and cost you more money.
Old 02-19-2010, 06:10 PM   #2
bankrobber
Drives: 2007 Yaris Hatchback
I dont think wear indicator because it only squeaks when pressing the brake pedal. I can be parked and it does it. Almost like a spring or something in the drum brakes needs to be lubed
bankrobber is offline   Reply With Quote
Old 02-19-2010, 06:52 PM   #3
markitect
Drives: Yaris
Can you hear it from outside the vehicle or just from the inside?
I've had a squeak when not even moving and it was the pivot on the pedal, little bit of grease took care of it.
markitect is offline   Reply With Quote
squeek ob1bogie DIY / Maintenance / Service 4 11-05-2009 11:16 PM
squeek squeek firefly1_0 General Yaris / Vitz Discussion 2 04-16-2007 02:02 PM
