Shut your fricken suck!!!
Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
Flush means having the rim lip flush with the fender, this can be done by stretching a small tire on a very wide rim with a very crazy offset not meant for your car. It also requires a quite a bit of poke, rolled and pulled fenders, wheel adapters and or spacers. It can also require grinding down the calipers to so the rims clear that depends on your back spacing. You also need either custom shims or camber bolts or companys make them. Extended wheel studs come in handy as well. You can achieve the look in many ways, custom shortend struts with cut springs, coilovers, air ride... The list goes on. If your not rubbing and rolling rough your not low enough! It can cause some major problems if not done right! I've already messed a fender up and went back to lowering springs until garm hooks me up with some new goodies!
You think your Yaris is low and fitted LOLzzzzz |
| Help Me Get That Slammed Look... | 9vapors | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 02-27-2011 10:27 AM |
| Daytime Pics of the Slammed 09 5door | counterfiend | Photo-Video-Media Gallery | 32 | 02-16-2010 02:04 PM |
| Slammed | Walter | Photo-Video-Media Gallery | 27 | 02-10-2009 12:30 AM |
