Old 02-27-2010, 09:43 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
When i get to work on monday ill check for TSBs for those codes and see if anything pops up. Seems like a lot of codes.
Old 02-27-2010, 10:02 PM   #2
Good Call on there being a TSB:
TSB T-EG048-07 (M.I.L. "ON" DTC P043E, P043F, P2401, P2402, & P2419)
Models: ’07 Yaris Liftback
Some 2007 model year Yaris Liftback vehicles may exhibit M.I.L. “ON” with DTCs P043E, P043F, P2401, P2402, and P2419 stored. The fuel tank filler pipe cover holder has been improved to prevent water intrusion into the Key Off EVAP pump module.
1. Using TIS techstream, check for Diagnostic Trouble Codes (DTCs).
If DTCs P043E, P043F, P2401, P2402, and P2419 are ALL present, refer to the
Technical Information System (TIS), 2007 model year Yaris Repair Manual,
Engine/Hybrid System – Engine Control – “1NZ–FE Engine Control System: SFI
System: P043E: Evaporative Emission System Reference Orifice Clog Up”.
2. Replace the charcoal canister, charcoal canister filter, fuel tank filler pipe cover, and the fuel tank filler pipe cover holder if water IS or WAS present in the EVAP system.
3. Using TIS techstream, clear all DTCs.
4. Perform the Automatic EVAP System Check and verify that NO pending DTCs set.
Old 02-27-2010, 10:49 PM   #3
RETRO
Drives: 2008 Yaris Hatchback
We had a 05 Corolla it had the same codes..We replaced the canister codes went away..About 2 weeks later they came back..Replaced the canister again thinking may have been bad..Codes where gone two weeks later codes came back..End up being ECU.The canister was $300 the ECU was $900.
RETRO is offline   Reply With Quote
