Old 03-01-2010, 06:52 AM   #1
Rikster
Rikster's Avatar
Drives: Toyota Yaris (2010)
I've got 15" 7J et 44 work cr-kai's, i was thinking of a 185/55/R15 tire! will this fit properly?
Rikster is offline   Reply With Quote
Old 03-01-2010, 07:02 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yes, 185's will fit, but with ET44, you can install 205's and have a very nice fitment.
Old 03-01-2010, 07:35 AM   #3
Rikster
Rikster's Avatar
i think 205's will make my car pretty slow, it's just a 1.0
Old 03-01-2010, 11:49 PM   #4
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Yes, 205's will slow you down just a little because of a larger contact patch and increased rolling resistance. Also, like Why said, they can weigh more because of thicker sidewall construction. These are my only regrets with this tire, so the next DD set to get will be the same brand but in 195.
Old 03-28-2010, 10:05 AM   #5
Billiam
Drives: '10 White Yaris 4D LB
Alright fellas...I just read this entire thread and it's kinda got me rethinking my possible setup. I thought I was going rather conservitive, but maybe not.
Here's what I was thinking:
TRD or NF210 springs
Rim #1 - 15x6.5, +38mm offset with a 205/55 tire
Rim #2 - 15x6, +39mm offset with a 205/55 tire
Will I really rub with either of these setups?
EDIT: Ok...forget the 6.5 inch rim. I just bought a set of OE xB1 rims...that'd be rim #2, 15x6, +39mm offset. So...like I asked, do you gurus think I'll be ok with a 205/55 tire with either of the above mentioned springs?
Old 03-29-2010, 09:24 PM   #6
Billiam
Anyone?
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
