![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
I have been saying this for years. If 20wt was OK, then the newer yaris would be spec'd for it and they are not. Thats not saying 5w-30 GF4 is a good oil. I would be hunting for a 10w-30 SJ or SL outdoor equipment oil for high stress applications. John Deere, Briggs and Stratton and mTD all make good HD oils - dont tlet the lawnmower/tractor bother you - these engine are air cooled usually have NO oil pump or filter and run at wide open throttle mid-high load. 4-stroke marine I/O engine oils are stout too.
#2 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
Actually, *do* let the lawnmower/tractor bother you. It's a completely different application. The requirements for these engines are completely different than for automotive applications. And you can't view oils along a one dimensional metric of "good" and "bad". That's far too simplistic. Oils are formulated for the specific application they are intended for. An oil may be (and probably is) superlative for your tractor but totally inappropriate for your car, and vice versa. (Although I should note that Scamsoil's marketing department *does* deceptively use *gear oil* metrics like the "four ball" test to market their snake oil products.)
On the topic of 10w30 vs 5w30... A 5w30 oil at 0F is thicker than a straight 30 wt at operating temperature. In fact, probably thicker than is optimal. All 10w30 is going to do is increase the starter load a bit. Use what the manufacturer advises instead of doing all this armchair second guessing. A possible exception to that, which may have some slight advantages, might be substituting a 0w30 for 5w30, if the (reputable) oil manufacturer rates it to be a suitable replacement for 5w30. |
#4 | |
#5 | |
Yes, all multivis oils are thicker at cold temps than at operating temperature. I mentioned the fact because it is widely misunderstood, and people who do that tend to recommend 10wX oils or straight weights.
I would not expect to be able to measure the difference between AFE 0w30 and a 5w30 without a lot of very systematic testing. I seriously doubt that your 5 mpg difference has anything at all to do with the oil. Engines don't see EP. They see sliding friction under very high shear conditions. Lot's and lots of it. What, exactly, do you think that extra EP additives are buying you? And what are the down sides, I wonder? You are, of course, free to second guess the engineers as much as you please. Especially if you are out of warranty. But you do it at your own peril. And I'd be particularly nervous going further and telling *other* people to use it. That said, if you are looking for an impressive oil that meets a range of European (and particularly German) high performance standards which almost no other does, and has an HTHS of 3.7... look to Mobil 1 0w40. If I were going to stray from the spec'd 5w30, that's what I would use. http://tinyurl.com/39b6cg BTW, why don't you care about your (and other people's) catalytic converter? -Steve Last edited by sbergman27; 03-05-2010 at 12:41 AM. |
#7 | |
Yeah, I had wondered about the vvt-i wrt viscosity. It's one of those little gotcha's that is easy to overlook, and an example of why I'm somewhat disinclined to stray very far from the recommendations. You just never know what esoteric details got discussed during the engine design meetings that you were not invited to. Engines (and oils) have gotten so complicated since when I was growing up in the 60s and 70s and we all just dumped 10w40 into our engines and swore by whichever brand we'd always used.
![]() Though I've tried to keep up through reading, the Yaris is my first foray into current technology on a hands-on basis. I tend to keep my cars for a very long time. My other cars are two 1968 Cadillac Fleetwood Broughams, which I grew up with, and my trusty 1988 Chevy Sprint Metro (really a Suzuki) which is about to turn over 350,000 miles. The Sprint is actually carbureted. Though it *is* an electronic feedback carb, so it has many of the advantages of FI. (Including DFCO, BTW.) But it doesn't support the fun toys like the Scangauge II. -Steve |
| TSB for steering pull? | vst | DIY / Maintenance / Service | 12 | 06-09-2007 03:40 PM |
| Finally! | KittenRD | New YARIS Purchase Forum | 6 | 01-01-2007 10:16 PM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 05:24 PM |
| finally found a good product to clean al plastic parts | Adriaan | Wash, Wax, Detailing, Exterior Repairs | 4 | 12-01-2006 03:45 PM |
| It's finally here! | Cathy | New YARIS Purchase Forum | 10 | 08-29-2006 11:08 AM |
