Old 07-07-2012, 12:07 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
mmm sq system can be addictive, and dangerous... some times when cruising on the high way, I just loose notion of where I'm am, dam music makes the car disappear and makes me feel I'm somewhere else! LOL
D.
CLA 250, 4MATIC
Old 07-07-2012, 12:10 AM   #2
derickveliz2
BTW,...
I've been playing with the left side tweeter, you guys are not going to believe what I'm trying to do!
Stage getting wider and deeper!
D.
CLA 250, 4MATIC
Old 07-07-2012, 09:21 AM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Do tell...Pictures are appropriate as well. :)
― Thomas Paine
Old 07-08-2012, 12:17 AM   #4
derickveliz2
No pictures today, still a secrete but I'm cutting metal again!
D.
CLA 250, 4MATIC
Old 07-08-2012, 02:02 AM   #5
derickveliz2
OK, I'm going to need help! (advice)
I'm trying to dig in the tweeter in the a-pillar into the metal, so how do I cut a round circle there? I did a few holes with a small bit just to check I get the clearance in the back and there are no structural members.
Why I'm doing this? is because I'm physically moving the tweeter's position by 3.5 inches forward and almost 2 inches towards the left side, I'm loosing about 3-4 inches of height but I did try the tweeter and stage still up high, so that I don't mind, but...
the fact that the stage got wider and deeper from actual location the end result it's very satisfactory, so I really would like to sink in this tweeter there, any advice is welcome! I guess I need a special tool?
These pictures show the left a-pillar and the round wood peace represents the circle I want to cut away:
D.
CLA 250, 4MATIC
Old 07-08-2012, 10:40 AM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
How were you cutting the hole? That angle is tricky because of the glass.
― Thomas Paine
Old 07-08-2012, 05:27 PM   #7
derickveliz2
I was thinking of making a series of holes around the perimeter then try to trim the imperfections with a dremel, but it's so hard to do each hole. I was hopping to find a good tool that would make my life easier.
D.
CLA 250, 4MATIC
Old 07-08-2012, 06:33 PM   #8
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
Why not just use a hole saw.. It looks like there is enough room to get a drill in there..
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 07-08-2012, 06:57 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That proposed hole is VERY close to the glass...that's the challenge. Know that the hole is only the size of a tweeter. Can a right angle adaptor give enough torque to drive a hole saw?
The dremel idea may be the best at the moment.
:) whadyamean you can't angle a sawzall in there?!? :)
― Thomas Paine
Old 07-08-2012, 08:19 PM   #10
07typeS
07typeS's Avatar
well aslong as there is no glass directly behind you're proposed hole, drill a centered pilot hole, and the hole saw will stay perfectly on line.. Ive seen one drift when dont that way..
But i get the hesitation.. I guess the dremel probably is the way you would wanna go..
And if you do try the sawzall, please get it on video!!!! haha
Old 07-10-2012, 01:06 AM   #11
derickveliz2
I did it! I did it!
Video1:*It was so easy that I took my phone for a video!
Video 2: Without holding my cell phone for video I could probably have done it in less than half of the time..
D.
CLA 250, 4MATIC
Old 07-08-2012, 11:11 PM   #12
derickveliz2
Some thing like a hole saw mentioned above is what I had in mind, Yes a dremel may be the power tool, now because of the angle of the a-pillar the dremel will not be exactly perpendicular to the cut, I hope that would not be an issue.
I'll stop by tomorrow at the local store and see if I can find a hole saw that fits the size of the hole that I need.
Thanks
D.
CLA 250, 4MATIC
Old 07-09-2012, 02:45 AM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
It's not the bit I'm concerned with in using a hole saw that close to the glass...
If you think a dremel is too big, a drill body is massive...one needs to get the hole saw bit straight on just like the dremel. Can you squeeze yourself into a good place on that dash to hit the pillar straight on with either option?
― Thomas Paine
Old 07-09-2012, 11:20 AM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I hate drilling into metal...
― Thomas Paine
Old 07-09-2012, 10:23 PM   #15
derickveliz2
Me too! I'm going to confirm that in a few minutes!
D.
CLA 250, 4MATIC
Old 07-10-2012, 01:23 AM   #16
derickveliz2
OK, this was so EASY, just like a hot knife on butter! best $15 bucks spent.
Now I have left tweeter as far forward and far to the left I possible can! I gain 5 inches and that's a lot! the distance from my left ear to tweeter now is 48" it used to be 43".
Stage is wider and deeper already!
Probably 5 inches sound meaningless, but you should hear the difference that it makes.
Picture 1: the a-pillar after cutting the metal
Picture 2: Tweeter in place! NICE! I'm happy.
D.
CLA 250, 4MATIC
Old 07-10-2012, 06:41 AM   #17
sickpuppy1
Drives: 2010 Yaris Sedan
What about the aiming? Looks like its down at the dash....
Old 07-10-2012, 09:49 AM   #18
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The aiming axis at that point will only have a minor effect. The gain Derick has from physical location is going to override the angle for the most part. What I'm going to be interested to see is how the mounting is integrated with the a pillar.
I see that mount is deep...really deep in there. What say you Derick? This may be a good experiment for horn loading...
― Thomas Paine
