Old 04-12-2010, 11:49 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
After some reading I realize that using an active crossover is the way to go, I'm heading a little bit towards sound quality here, and by doing so I think I'm going to loose my rear speakers, (this is for a good staging, I assume).
I'm OPEN to any suggestions here, this is my plan, if you feel like suggesting a better way or proper way my ears are wide open, I'm here to learn and to accomplish as much as possible, there are some variables like things that I already have, but the more input we get the better.
Thank you,
D.
CLA 250, 4MATIC
Old 04-12-2010, 12:31 PM   #2
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
What rms are them solobarics rated at ? and have you checked the airspace they'll require ?
Old 04-12-2010, 12:47 PM   #3
derickveliz2
Each is 350 RMS when installed in 0.66 cubic enclosure, I had these puppies in my truck and the box fits inside the Yaris trunk, so it's an easy drop install if I'm lazy. LINK-SOLO-BARIC Manual
D.
CLA 250, 4MATIC
Old 04-12-2010, 12:52 PM   #4
_S7V7N_
_S7V7N_'s Avatar
Wow, i thought they'd ask for more space, that's not bad at all. Install looks well thought out.
Old 04-13-2010, 10:10 AM   #5
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Are those new solos? That looks suprisingly like my old Solo D series rounds...
I love those old round D series subs. I had two 15"s of two ZR360s ten years back. Fun times.
As for criticism of the layout? Meh, I'd say the weak part is going to be the Pioneer EQ. I understand then need though. I'd say do as much tweaking with the amplifiers and the ReQ as possible before installing that.
― Thomas Paine
Old 04-13-2010, 10:42 AM   #6
derickveliz2
Yes! they are the old round D series, they used to sound/feel very good, not as low as I would like, and since I already have them I guess I'll use them for now.
I agree with you about the Pionneer EQ, should I be looking for other kind, brand, new, EQ? any suggestions will be appreciated.
Thanks!
D.
CLA 250, 4MATIC
Old 04-13-2010, 12:04 PM   #7
derickveliz2
Would this "FOUR.1" Would be a good option?
LINK
Thanks
Derick
CLA 250, 4MATIC
Old 04-13-2010, 10:58 AM   #8
derickveliz2
I went to bed last night at 4 o'clock in the morning...
My car had a terrible noise coming from the front bumper, last year a lady hit my car in a parking lot (backing up) the lower grill broke and in the last couple of weeks I found out that the custom Grill came off on one side.
I started at 10pm and end up at 4am, no more rattles every time I close the doors. Since I took the bumper off and fixed it, I installed a pair of Hella Super Horns.
I'll show pictures later. I was very tempted to put some deadening on top of the plastic wells, I couldn't resist and did put a little strip, I'm sure it's not really going to help.
D.
CLA 250, 4MATIC
Old 04-13-2010, 02:28 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Perhaps...
I still think you should adjust and then plug in another component if you need to.
― Thomas Paine
Old 04-13-2010, 02:37 PM   #10
derickveliz2
Perhaps...
Thanks, I'll do that.
2 days left right?
D.
CLA 250, 4MATIC
Old 04-13-2010, 04:48 PM   #11
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I'm all for the EQ boner and such... but before you go out and spend $200 or more dollars on eq's you may or may not use... install your parts, then add one piece of signal processing at a time. Tweak with it as much you can over the course of a week or two, then evaluate if you want more tweaking capability.
remember that your signal quality is technically going to go down with each component you put in the signal chain before the speaker. A single processor like an eq is good, but if you start adding all kinds of goodies like dash eq, trunk eq, line boosters, active crossovers and so on.... you're just getting away from KISS, and that is rarely good.
I'm sure the four.1 is a fun toy....and if given one, would install it in a minute. I just wish it had more like 7bands, or... say 4 bands, but all in the 35-200hz range, so I could dial in the sub/midbass perfectly from song to song very quickly while driving.
Old 04-14-2010, 02:04 AM   #12
derickveliz2
Thanks, looks like a plan.
I've been putting more CLD tiles and RAAMmat BXT inside the front right door, next will be to remove the OEM speaker.
Here are the pictures of the front without bumper; I did put a Tile of CLD in the back of the licence plate and 1/8" CCF (faom).
D.
CLA 250, 4MATIC
Old 04-14-2010, 07:58 AM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The 20th is supposed to be our final day.
Then I get on the horse to install my system. I'll probably release tutorials as I'm going along. Hopefully I can have the install complete within several weeks. I've got NOTHING else to do since I don't have to go to work for 90 days...
― Thomas Paine
Old 04-14-2010, 09:33 AM   #14
derickveliz2
The 20th is supposed to be our final day.. I've got NOTHING else to do since I don't have to go to work for 90 days...
Awesome!
Looking forward to see a professional perform.
Thanks
D.
CLA 250, 4MATIC
Old 04-15-2010, 11:46 AM   #15
derickveliz2
I removed the OEM front right speaker, I read somewhere that you have to use a drill, I started with a small bit, didn't work so I use a bigger one.
I can't believe how light they are, here is a picture next to the new ones. I'm going to try to use the OEM spacer to install the new speakers, we'll see if it works.
Also I was looking for a water resistant sound absorbent material to put inside the front doors to help with the acoustics of the speaker (remember the door becomes a speaker box) so I found this "Funnoodle" thing on sale for $2, cut in half; see picture
The other pictures show CDL Tiles and some Raammat. Just by taking care of the resonance on the door outer and inner skin, I can tell that there is a big difference in noise level coming from the naked door.
D.
CLA 250, 4MATIC
Old 04-15-2010, 04:31 PM   #16
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
keep in mind that the size of a magnet does not matter on how good a speaker is. Common misconception. Furthermore, it doesn't even tell you the strength of the motor... the way that the voice coil is wound and the height of the top & bottom plates have more of an effect on the motor's strength than the size of the magnet.
Old 04-15-2010, 04:39 PM   #17
derickveliz2
Some thing funny happened to me...
I had in my Tacoma a pair of (Pioneer) Premier 6.5 component speakers (not cheap) and guess what? I end up putting back the OEM speakers because they sound much better than the premier, although the OEM speakers from the Tacoma are much better quality than the ones I found in my Yaris.
I didn't know that the Zeus came with a blue LED inside! I'm going to have to play with that!
D.
CLA 250, 4MATIC
Old 04-15-2010, 05:23 PM   #18
derickveliz2
At Lunch I went for the right front seat, I was really scared about taking it off, I read in another thread people having problems but it was a piece of cake! took me no more than 10 minutes!
BTW, mean while I was over there I took the glove compartment off just to realize that there was no CABIN AIR FILTER, I did a small search here in YarisWold and found out that it's common. But I got so mad I wrote down an email to the dealer! and I got a stupid answer and at the end I got my self a free Cabin Air Filter. here are the emails...
__________________________________________________ ____________
I can't believe I got a new Toyota from you, and I just found out it came without a cabin air filter, that is a shame.
Thank you,
Derick Veliz
__________________________________________________ _____________
Hi this is Bill from Boch Toyota
I called Toyota to try and get an answer for you about the cabin air filter On the Toyota Yaris.
The only thing they could tell me is that due to the small volume of interior space the cabin filter does not work the same as in bigger interior cars, so Toyota decided not to install them, but if the customer really wants one we can try and fit the corolla cabin filter and tray. The part sells for around $27.00 plus tax
Plus the installation. I hope this answers you’re question.
__________________________________________________ ____________________
That is not a Toyota answer, please. I also have a corolla and a tacoma and let me tell you that the interior space of my corolla is almost the same as the Yaris.
the manual states you shouldn't operate the a/c without it
p/n 87139-YZZ08
Thank you,
Derick Veliz
Hi this is Bill from Boch Toyota parts again as previously stated I was passing the information Toyota gave me to you.
But I can say that if you feel you really want the cabin filter installed you are more than welcome to bring in you’re yaris and we will try and see if any of the other filters fit at no charge to you for the first filter and installation
I know this has been discussed before but just wanted to share with you.
Thanks
D.
CLA 250, 4MATIC
