Old 03-03-2010, 01:00 PM   #1
cdydjded
Drives: Yaris LB Turbo
Here is a good article:
http://www.carcraft.com/techarticles...ter/index.html
My car is @ -22 so -20 is not that different. You low compression issue could be one of the following problems:
Piston ring end gap wrong
Piston to cylinder wall clearance wrong
Valve to valve seat problem
Crack or broken ring lands
These are just a few that I can list. Im not saying it has to be one of these, but its a possibility.
cdydjded is offline   Reply With Quote
Old 03-03-2010, 03:27 PM   #2
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Nice test I didn't know about it since now. Interesting tool ... what brand do you recommend?
Old 03-03-2010, 05:07 PM   #3
cdydjded
I dont have a specific prefrence, here are a few:
http://www.google.com/products?hl=en...ell=1&oi=spell
Old 03-03-2010, 05:10 PM   #4
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
If you have a compression tester, you can easily tell if it's the rings or the valves which are causing the problem. Run the compression test as you would normally and take note of the reading.
Then remove the compression tester fitting and drop a teaspoon of oil (any normal mineral oil will do, castor oil, motor oil, doesn't really matter as long as it is thin (ie. not gearbox oil)) down the spark plug hole and then repeat the compression test. The oil you put down the combustion chamber helps the rings to seal better. If the reading is the same as before the oil was added, then the problem is in the head (valves, valve guides etc). If the reading is dramatically better than without the oil, then you look towards your pistons and rings for the problem.
If the reading is only slightly better than before you added the oil, but still low compared to the other pistons, then you possibly have a bent rod.
rob323 is offline   Reply With Quote
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
