#235 |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
OR >>> Garm's Intake Mainfold
![]() I'm waiting . . . BTW just found this on my pc > http://www.youtube.com/watch?v=u0wage2LBdM
#236 |
This week we installed Siemens Deka 4 630cc injectors. Since the Siemens housing length is slightly different from original toyota injectors they needed to be "modified" to match the fuel rail.
Now needs tuning from scratch, I hope it makes real power with these on
#237 |
ooh man can't wait for new results!! I have great hopes for this project!
#238 | |
Guess what? ..... if all goes well I think I will be the one to trial the Gude Performance Head package on our 1NZ. I already send him an e-mail to get some more details on cams.... Stay tuned! |
#239 |
You're drag racing tomorrow? or tuning tomorrow, or both... ?
#240 |
#241 |
oh "street tuning", gotcha.
#242 |
Some bad news....
![]() Yesterday we done a compression test since we are still having trouble idle and slow runing the engine. Well it result that 2 cyclinders are loosing compression and probably some valves not sealing properly... There is also a problem to convert the engine with the authorities (due to some changes in law) since there is a fine difference due to bigger displacement (probably within $2000 range ) So we are now intending to modify the 2NZFE 1.3L engine block to match the 1NZFE rods and in the meantime solving aswell the problem of the compression. We have to measure all the necessary points of the block in order to make this happen....This will cost lots of money & time and since I am out of cash it will be a while to update my status.... |
#243 |
aw, so sorry to hear this. Do you think the motor came to you with these problems?
Is this your first compression test on it???
#244 | |
I am thinking of making a 2NZFE block conversion to match the 1NZFE rods. Since the 2 blocks have the same bore size of 75mm, what issues (if there are) I could face doing this? Is there something I need to know before I get into it or else is it possible to make it without much complications? |
#245 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Garm... and can assure you and Parma, that the motor had excellect compression when we sold it.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#246 | |
When the engine arrived, it was opened and checked that all parts match the details. After assembling a compression test was made and marked loosing. The mech said they solved it and I continued to finally tune in. When we noticed having several idle and slow running problems we checked again to be sure and found loosing again. I think there is a funny thing around and someone fu**ed me from behind on this |
#247 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
A proper test that would have determined the condition of this engine is not a compression test, its a leak down test. A compression test only tells you the compression psi in the cylinder chamber but it does not telling you if the piston rings or valves are sealing correctly. BTW how much vacuum was you boost guage reading at idle?
#248 | |
Tell me more about this leak down test |
#249 |
Here is a good article:
http://www.carcraft.com/techarticles...ter/index.html My car is @ -22 so -20 is not that different. You low compression issue could be one of the following problems: Piston ring end gap wrong Piston to cylinder wall clearance wrong Valve to valve seat problem Crack or broken ring lands These are just a few that I can list. Im not saying it has to be one of these, but its a possibility. |
#250 | |
#251 | |
http://www.google.com/products?hl=en...ell=1&oi=spell |
#252 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
If you have a compression tester, you can easily tell if it's the rings or the valves which are causing the problem. Run the compression test as you would normally and take note of the reading.
Then remove the compression tester fitting and drop a teaspoon of oil (any normal mineral oil will do, castor oil, motor oil, doesn't really matter as long as it is thin (ie. not gearbox oil)) down the spark plug hole and then repeat the compression test. The oil you put down the combustion chamber helps the rings to seal better. If the reading is the same as before the oil was added, then the problem is in the head (valves, valve guides etc). If the reading is dramatically better than without the oil, then you look towards your pistons and rings for the problem. If the reading is only slightly better than before you added the oil, but still low compared to the other pistons, then you possibly have a bent rod. |
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
