Old 03-06-2010, 02:51 PM   #17
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
There's a reason the magic happens in the midrange...
That's where human's hearing is the most sensitive or attuned.
Hey Taln, can you run a graph for the IDQ 12v3 D4? I'd really like to know what a pair of those in 1 cube each sealed with 750 Watts a piece would do...
here's the frequency response, and cone displacement graphs... you'll well within the X-max, so distortion should be low. QTC of a 1cuft box per sub is .691, fairly low for a sealed setup.
Red line = 2cuft sealed (1cuft each) looks like usuable range down to 30hz.
Blue line = 10cuft sealed (to simulate what an IB setup might look like)
The IB can safely play about 5hz lower than the Sealed can, I don't know what the x-mech is on that sub, so its possible it could safely play much lower, but with added distortion.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
