Old 03-08-2010, 01:09 PM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Looks like they're not good at giving info...Loll deff not an Sq sub, i guess we'll just have to go with noise....I guess what would be the best box for Spl.
Old 03-08-2010, 06:04 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
spl boxes aren't something you want to have in your car.... trust me, i've done it, and a box that is even remotely designed for SPL is annoying, and dangerous to use for daily driving.
A street better alignment is what you want, which would be tunning in the 35-40hz region + a subsonic filter set just below tuning (say 5hz below).
it'll be loud, muddy, and .... did I say loud?
Old 03-09-2010, 12:48 AM   #3
_S7V7N_
_S7V7N_'s Avatar
That sounds kind of ...Fun Can that design have them L ports in there? or is it going to be them round ports ? And i seen them recommend polyfill, i've used this in a sealed box, but a ported ?
Old 03-09-2010, 11:28 AM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
the shape of a port really doesn't matter... what matters is how long the port is & the area of the port. you increase the area, then you increase the length of the port.
the nice round aeroports are very smooth and help keep port noise down, I've only used them once on my own boxes, generally I do slot ports cause they are free, and aeroports cost like $15 a pop... My HT sub I had some issues with the size & length of the port, going with an aeroport helped me out... its kinda like cheating.
If you do a slot port, I recommend taking a 1/2" round over router bit to both ends of your port just to help give it the tiniest bit of flare.
Old 03-09-2010, 11:34 AM   #5
_S7V7N_
_S7V7N_'s Avatar
In your opionion if i started out at about 2 cu ft of airspace per chamber tuned to 35 Hz, would that be a good starting place ?
http://www.kicker.com/sites/default/files/CVR_0.pdf
I think that site had more of the tech stuff, 07CVR124
Old 03-09-2010, 06:01 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
nice, those are the specs I wanted... now... do you have the DVC4ohm or the DVC2ohm sub?
Old 03-09-2010, 11:13 PM   #7
_S7V7N_
_S7V7N_'s Avatar
Dual 4 Ohm
Custom Lift Back Hidden Sealed Woofer Box TinyGiant DIY / Maintenance / Service 42 04-15-2010 03:36 PM
Sub Box Desgin talnlnky In Car Entertainment + Electronics (audio / video / alarm) 5 08-23-2009 01:45 AM
RMS capabilities Slick In Car Entertainment + Electronics (audio / video / alarm) 31 08-21-2009 09:52 PM
Custom sub box for a sedan... Spades In Car Entertainment + Electronics (audio / video / alarm) 3 12-07-2008 06:42 PM
DIY: Custom Hidden Trunk Box (08 Yaris 3D) goku87 In Car Entertainment + Electronics (audio / video / alarm) 0 10-19-2008 05:43 PM
