Old 03-11-2010, 02:56 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Yep, your not getting all your oil out. Using ramps? That'll mess it up. Mine usually takes 3 + 3/4 qt with a good long drain at various angles using a floor jack. Dont over fiil or it will dogg down.
TheSilkySmooth is offline   Reply With Quote
Old 03-11-2010, 04:00 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
isn't the drain port at the back of the pan? therefore if you drove the car up on ramps, the oil would be more poised to exit out the now-lowered oil pan bolt..
Originally Posted by xnamerxx
you nailed it sir.
Old 03-11-2010, 06:24 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
dude... they do the ramps on the rear tires in texas... you know how everything is backwards down there.
Old 03-15-2010, 02:32 PM   #4
severous01
i'm using an alignment rack at the place i work. BMW/nissan/honda...so i know the car's level.
it doesnt really matter, when i check the stick after first turn on and shut down to check it's always on the line. and the oil is clean, just like it came out of the bottle...very little color change
but any way, it doesnt really matter. i change my oil at service interval and i'm using higher than standard oils, full synthetic so even if there's a quart left in there it's still not dead enough to change
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
when to do oil change kaymm DIY / Maintenance / Service 6 10-28-2006 12:33 AM
Dealership wants $64.99 for Oil Change? ScottFern DIY / Maintenance / Service 15 09-21-2006 11:49 AM
first oil change? wushumasterku DIY / Maintenance / Service 41 06-07-2006 10:32 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
