![]() Drives: YarisMerahStandart09 Join Date: Mar 2010
@Steve Bergman
is there any wax with non abrasive? @S7V7N: what is liquid glass ?? is it safe for the paint and varnish ? |
A guy i knew had a fleet of Mercedes, this is all he used on them, so if it's good enough for Mercedes it's good enough for or Toyota's Loll
Got this description off the amazon site. Product Description Product Description This amazing special formula makes it possible to coat your vehicle with a clear, hard, smooth, and mirror-like finish with a minimum of effort. The finish will not crack, chip, peel, or turn yellow. Liquid Glass is safe for use on today's clearcoats, gelcoats, acrylics, metalflakes, candy apples, pearls, plastic paints, epoxies, urethanes, etc. Also does an excellent job on chrome, aluminum, stainless steel, brass, etc. Use on automobiles, trucks, vans, RV's, motorcycles, and other vehicles. Provides excellent protection against normal road, atmospheric, and other sources of pollution, dirt, etc. Retards oxidation of painted metals and fiberglass. Also use on aircraft to protect, keep clean, and reduce surface friction. It also has hundreds of uses in and around the home, (for example, Formica, ceramic tile, jewelry, glass, sporting and camping equipment, etc.)
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
If the bottle talks about "Cleaning", it's likely to be more abrasive than a product that doesn't.
Since my finish is in pretty good shape, I've taken to just keeping a bottle of Turtle Wax spray in the trunk, with some terrycloth towels. After exiting the car wash, I just wipe it down with the spray, and dry it with a clean dry towel. It's no harder than just towel-drying, really, and I know I'm always freshly waxed. The sprays have lower durability than pastes and liquids, but they're easy enough to apply that I do it after every wash. The liquids and pastes I tend to put off doing for longer than I should, because of the hassle. I figure oxidation is not so much about how often you wax... but how often you don't. When it's uncomfortably cold outside, and they're using salt and sand on the roads... and when it is uncomfortably hot outside, and sun intensity is at its peak. Note that despite any claims, the micro-thin layer of wax or silicone in car waxes can't really filter out much UV. But they do protect the clear layer which does contain an effective UV blocker. And BTW, so far as I know the spray waxes contain no abrasives at all. -Steve Last edited by sbergman27; 03-29-2010 at 07:10 AM. |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
I agree with Steve. I use Meguiar's Ultimate Quik Wax after every wash. It is very easy to use and you can even use it on your windows. It works as good as Rain-X. I just spray it after washing and dry with a microfiber cloth.
| Waxing the Yaris? | YotaYarisUSA | Wash, Wax, Detailing, Exterior Repairs | 134 | 09-12-2010 07:22 PM |
| washing and waxing | eddy | Wash, Wax, Detailing, Exterior Repairs | 41 | 07-28-2010 10:28 AM |
| Just did a clay bar and waxing.. | mtshum | Photo-Video-Media Gallery | 15 | 07-21-2009 05:26 PM |
| Washing & Waxing | coheed | Wash, Wax, Detailing, Exterior Repairs | 10 | 01-07-2009 05:49 PM |
| After Waxing Products | jonr0613 | Wash, Wax, Detailing, Exterior Repairs | 2 | 09-12-2006 06:58 AM |
