![]() Drives: 2008 Yaris 5spd, 2005 GLI 1.8T Join Date: Aug 2009
''Collects very well''? Did I read that correctly? You use a $200 scan tool that has 5 buttons to figure out all the necessary information? Soo... Can you read fuel maps/trims? Read individual measuring blocks for injector pulse width and duty cycles? Open and closed loop? Monitor and log multiple sensor outputs? Suggested vs. actual MAF, MAP, TB measurments? ... Do you even have wideband oxygen sensors to measure your precise fuel combustion? Oooor... Do you just have some magic program that calculates fuel mileage? Cause I have that on my dashboard in the Jetta... I don't need a scan tool to do this. I can just go ahead and do it for you if it's gonna be the same thing.
Come back when you have a TIS Techstream. Until then, Mr. Burgman, you can get yourself a nice magnetic drain plug, and again, as said before, drive one cycle of 5000 miles driving cold, right off the bat... No waiting. Then another 5000K miles letting the car warm (in winter months), or giving her 10 seconds minimum for proper distribution of lubrication if in summer months, then compare volume of metal material on the magnet. If you don't give a damn about engine wear and all you care about is fuel mileage, then by all means let me dismiss this situation now... Because you've got larger problems in life to deal with if you consider engine wear<minimal fuel savings. Last edited by Boost Addicted; 03-13-2010 at 03:53 PM. |
#2 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
I'm not addressing the magnetic drain plug bit since I assume that it was not intended to be taken seriously. I suppose something might be done using UOA results, to the extent that one trusts them... which I don't particularly. BTW, you didn't answer my question about your preferred target temperature for the warm ups. Also, you really need to calm down. Your post is borderline irrational, and frankly, inappropriate in tone. In short, you seem to be frothing a bit. This is the only response that I intend to make to a nonconstructive post in this thread. Life is too short to waste time on such things. -Steve Last edited by sbergman27; 03-13-2010 at 11:08 PM. |
#3 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
I 'll say something for engine wear and toyota motors. I operate a 5VZFE. I owned my 4runner from new in Dec 1998 to today, it has 190,000 + miles on it. all it ever got since mile 600 was mobil 1 5-30 every 8000 miles. (plus timing belts and regular owners manual maint. at the dealer) I always, ALWAYS just jump right in and drive it, zero or minimal warmup (only as long as it takes me to adjust whatever I am doing. I get in car and always go immediately.) transmission and engine still run better now than the first 10,000 miles. ya I don't stomp it hard until it is warm but I go the speed limit. engine is still maybe 40 or 50 deg and climbing I am already doing 40mph. so....I live in NE and oh yeah you betcha I do this when it is 10 deg out as soon as I get in it I drive it. I start the thing so often I am on my 3rd set of starter contacts. and guess what ? NO damage to motor of any significance...it is just getting broken in at 190,000 miles. today, it still gets better than EPA, in 8000 miles it burns only 2mm of oil level on the dipstick and passes emissions with tests with ease. it makes all the compression it should, it makes more BHP than it should on 87 octane no engine mods whatsoever. this is not the 50's anymore with your grandpa-era motors found in high school shop class... ...engine wear schmengine wear just drive the thing immediately it will not do any harm if you plan on keeping a toyota..what ? 11+ years like I have...and it is real in-my-driveway-come-look-at-it-for-yourself results, not some crap from a book I will say it may not be fair to compare a 5VZFE...the motor is legendary as being absolutely bombproof...same with my A340 tranny and transfer case |
127.0.0.1,
My Chevy Sprint (Suzuki 1.0L 3 cyl) has about 350,000 miles on it and has had 3 overhauls. The first one was at 140,000 miles and not due to any sort of wear, but due to a ring which had lost tension. (This engine uses a special low friction ring configuration with 1 oil ring and 1 compression ring, so there is not a lot of margin for error.) Typically, over temperature is the cause of this. But we never determined for sure. Anyway, the engine looked great so we just did rings and bearings. Though the existing bearings actually looked pretty good. The second overhaul was at 260,000 and was actually due to a mistake made during the first overhaul which ended up causing the timing gear keyway at the front of the crankshaft to wallow out, destroying the crankshaft. We were impressed that at 260,000 we only had about 0.004 - 0.005 cylinder wear. We did rings and bearings again, in addition to replacing the crank. The existing bearings looked remarkably good. And the crank was fine... except for the keyway. At 318,000 miles it cracked a piston. Probably that 0.004 - 0.005 cylinder wear had increased and fatigued the piston. This time we bored it and went with new pistons. The cam shaft was still in great shape. No action was necessary there. So that engine went 318,000 miles before a wear condition caused problems. The first 2 overhauls were completely unrelated to wear. I've always been a fan of Mobile 1, which is what I always attributed the low wear to. But I've never been one to formally warm an engine up. I do try to go easy on them until they are at least partially up to temperature. -Steve |
#5 | |
1. You have put your 4Runner on a dyno? Makes MORE BHP than it should? I'd like to see that dyno sheet. 2. You go 8,000 miles before changing your oil... And continue to say you have more EPA horsepower ratings, fuel mileage, etc?... Right. Proof? 3. ''All the compression it should'', yet you don't have a number... 4. No damage to the motor whatsoever? So you must know of Blackstone Labs? May as well post up your progressive stack of every oil analysis you've gotten, along with that dyno sheet. I'm afraid, my friend, I do not go to high school , so the cars you speak of, ''grandpa era'', are not a factor. But it made you sound kinda badass I guess ![]() Mr. Burgman... I'm seriously convinced you have no idea what you're talking about. I'll take your ignorance to my last post as a sign of you not knowing what aaannny of that actually is (measuring blocks, open/closed loop, etc). Using biiiig sophisticated words doesn't help the fact that you're talking from your ass... And speaking to me as a lesser person isn't gonna go very far. Props for trying though. This is a technical forum, not a pissing contest ( ).And in all seriousness, the two of you should check out mobil 1's formula list... |
#6 | |
You are preaching 'technical', yet cannot even read correctly. idiot. I am not saying it will never wear out, I am saying that 11 years of 'start and go immediately' have no real impact on the thing as a daily driver. you can sit and warm up your car all you want there, Chieftain... all you will do is waste gas. I can start and go and still have a decent engine at 11 years plus. so there. real world use. if you race a car that is a different matter entirely. warm ups are needed on race engines. yes, a warm motor does perform better, but is warmup needed on a daily around town driver. NO. Whatever. I am not into finite oil or engine analysis on my cars. it is a friggin car, not a nuclear warship. I worry more about steam engines and ceramic impellers in real life. ---- tests were done at 166,340 miles dyno results were original dyno run at 2000 miles was 163 hp /234 torque (186 hp adjusted) 166,340 miles run was 168 hp /234 torque (190 hp adjusted) compression tests at 166,355 miles 1- 178psi 2- 175psi 3- 181psi 4- 188psi 5- 182psi 6- 179psi all 6 tested on warm engine within 2 minutes I did these checks because I -was- gonna sell it, but then decided I will never sell it Do I know of Blackstone Labs ? sheesh are they any better than Lockheed Martin or Pratt and Whitney at materials analysis ? want me to send you some NASA stickers ? done with this one. pointless. Last edited by 127.0.0.1; 03-14-2010 at 01:29 PM. |
From my own experience, I would be inclined to say "impressively little" wear. Significance is relative. I tend to keep my cars a very long time. Like 20 and 40 years. (Call me sentimental.) And I dread overhauls. They always seem to result in some sort of complication. And, at the very least, expense... no matter how long the original lasts. It's possible that a certain amount of extra warm up might be beneficial over the very long run. Or... it could be, as you say, insignificant... even in my situation.
It's an interesting topic. Actually "topics", since we have two questions. How do warm ups affect fuel economy under different use scenarios? And how do they affect wear? I was planning on scoping out the easier of the two: fuel economy, this week. But surely Car & Driver, or Consumer Reports, or *someone* with better resources has researched these things. I just now got back from a long trip and am not too keen on a Google-hunt, sorting out all the credible wheat from the unreliable chaff. But I figured I'd mention. -Steve |
#8 | |
#9 | |
I don't think that this thread necessarily has to be a waste of time. It could be a good thread or a bad thread, depending upon how the participants handle it. 127.0.0.1 and I tend toward the "just drive it" opinion. You're the fellow carrying the "warm it up first" side. And that's a very reasonable view. But maybe it seems like we're ganging up on you or something. I don't know. I'm less concerned about right or wrong, or the winning or losing of an argument, than I am with what useful, helpful, or education information comes out of the thread. I'm wondering... where is the pivot point? How far or little can you push the throttle before wear per mile stops decreasing and starts increasing... or fuel per mile stops decreasing and starts increasing. -Steve |
| Fuel Level Gauge Stuck ? - 2007 Yaris Sedan | kaboom | New YARIS Purchase Forum | 9 | 05-15-2007 02:58 AM |
| Fuel consumption US Yaris vs. Canadian Yaris | Driver | Performance Modifications | 8 | 10-29-2006 02:27 AM |
