Old 03-14-2010, 12:00 AM   #1
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Originally Posted by froger View Post
TRD SPRINGS AND SHOCK ,TRD SWAY BAR , TOYOTA OEM CAMBER BOLTS
THIS IN REGARDS TO WHICH IS BETTER , THIS ALL DEPENDS ON THE ALIGNMENT SET UP. BY FACTORY YARIS DON'T HAVE A RACING SET UP SO WHEN YOU LOWER YOUR CAR WITH FACTORY SPECS, IT WON'T HANDLE WELL .THE KEY THING IS TO ADJUST THE CAMBER ,ZERO OUT THE TOE, IF YOU ARE USING SPRINGS BUT IF YOU PLAN ON USING FACTORY SPECS OR IF YOUR NOT A PERSON WHO IS MECHANICALLY KNOWLEDGEABLE JUST STICK TO THE SWAY BAR . THE REASON WHY THE SWAY WORKS ON FACTORY SETTING IS BECAUSE THE FRONT TIRES LACK THE ANGLE NEEDED TO CONTACT THE ROAD DURING CORNERING ,WHAT THE SWAY BAR DOES IS IT DISTRIBUTES MORE OF THE WEIGHT TO THE REAR CAUSING THE REAR TO TAKE MORE OF THE CORNERING FORCE. THIS INTERN CAUSES THE REAR TIRES TO HEAT UP FASTER AND LOOSE TRACTION ,THIS IS WHAT CAUSES THE OVER STEER OR NEUTRAL FEEL WITH THE SWAY BAR. I USE THE SWAY BAR ONLY BECAUSE IN WINTER THIS RACING SET UP WITH THE COMBINATION OF WINTER TIRES BECOMES TO UNSTABLE SO I ADJUST IT SO
I HAVE LESS CAMBER AND MORE TOE ONLY IN WINTER TO MAKE IT A LITTLE MORE STABLE.
IMHO... There is so much wrong with this explanation...
Old 03-14-2010, 09:48 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
If he's talking about a front swaybar, it's somewhat correct. Front swaybar transfers weight to the outside rear tire giving it more traction. Great for most RWD cars. Not so much for a FWD car.
What a stiffer rear swaybar does is transfers weight to the outside FRONT tire, which is the tire that is doing the most work when your FWD car is trying to power out of a turn.
It accomplishes this by taking weight off of the inside rear tire in a turn. Since weight transfers diagonally on a car, any weight taken off of the inside rear goes to the outside front.
Ain't physics fun?
Old 03-19-2010, 09:33 PM   #3
eht13
Drives: .
THIS is pretty interesting... this explanation and information is pretty accurate, right?
eht13 is offline   Reply With Quote
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Progress Lowering Springs vs Tanabe DF210 lowering springs jyfro_13 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-24-2010 02:38 AM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
