Slowy getting there
Another R-comp thread
Has/does anyone auto-x with r-comps on their Yaris. I don't want to hear the story of the guy rolling his Yaris. I want to know from personal experience people that have.
I would like to know what type of tire you ran and your suspension set-up for it.
![]() ![]() Drives: 07 Yaris Sdn, 97 4Runner Join Date: Jul 2006
I know Garm has a set, but hasn't run them yet. I'm thinking about doing it next season. Not sure yet though.
resident senior
Here are some vids of me in my Yari . The white Yaris (07) has TRD shocks with Tein springs . The blue Yaris (09) has TRD shocks/springs/sway . Both Yari utilize the same wheel/tire combo , which is 16x6.5 +40 SSR Type C wheels in conjunction with 205/45/16 Hoosier A6 tires .
http://s208.photobucket.com/albums/b...MyMovie1-1.flv http://s208.photobucket.com/albums/b...nt=YarisIX.flv
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
i ran hankook z211 C30 compund 205-50-15 last year. they did very good imo. so much grip, the wheels wouldnt lock up no matter how hard i stood on the brakes (240lb dude). never every felt like it was gonna roll over.
suspension setup started off as out of the box megan coilovers, but now... Front Megan Shock Tubes WRX Koni inserts 450lb Eibach 2.5id Spring Poly Bushing under the top mount plate Ford Focus Endlinks Rear Ford Focus Koni shocks Megan Spring Bases Eibach 500lb 2.5id spring TRD swaybar |
Slowy getting there
Where did you get the megan shock tubes and any problem fitting the shock you used.
Damn, SethMan has a crazy a$$ setup!!!
#8 | |
the top of the front shock unscrews from the threaded shock tube. pull the guts out and put whatever you want inside. just so happens they fit koni inserts from my wrx quite well. the rear focus shocks bolt right up. The eibach race springs are the same 2.5" inside diameter as the megan springs, i got them at a swap meet for $1 per spring, the top poly bushing is a left over from a rear differential outrigger bushing kit for my wrx, tool all the slop out of the front mount, that 1/4" that it could move up and down is gone. i dont think its that crazy, ive seen way more crazy stuff out there, my car is still comfortable to drive everyday. |
thanks for sharing sethman.
Slowy getting there
Thank you for the info! I can see it helping people try new things...
I raced three events on my rcomps and never rolled? I think you'll be okay ;)
Under the right conditions most any car can get on two wheels. Your driver inputs will have the biggest effect on this. Don't get in over your head and you wont have a problem.
Avoid getting the car sideways, and avoid the late brake turn-in off throttle combo, If you are on the gas it is much harder for the car to get up. I saw this happen first hand, it was awesome.
Slowy getting there
Would doing the shock setup that Seth_man did be legal in HS?
Not quite. MUST use stock springs in HS.
Slowy getting there
If using the shock tubes and shocks for different makesis ok I guess the Yaris does have konis available for it.... hmmmm
#18 | |
His spring change would not be legal.
| The open political discussion thread. Read the first post! | eTiMaGo | Off-topic / Other Cars / Everything else Discussions | 342 | 09-15-2009 12:34 AM |
| Yaris of the Month Feedback Thread! | jekqmb | General Yaris / Vitz Discussion | 1 | 09-01-2009 12:34 AM |
| The Official "Bambo the Yarisworld Traveler" thread (V2) | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 528 | 06-22-2009 03:58 PM |
| Aftermarket rim thread vs official wheel guide | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 04-01-2009 12:11 PM |
| Post Whores-aka Yaris chat thread | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 21 | 07-12-2007 05:37 PM |
