![]() Drives: silver 07 effin yaris Join Date: Nov 2006
mr2 rims?
i was wondering if anyone thought about putting the toyota mr2 rims on the yaris? i think it would look really good what are some of your oppinions.
yaris 3 dr liftback: 20% tint shaved emblems blue lit hvac coming soon: c one front strut-on the 30th w00t tien s tech springs 16 in ssr comps short ram intake and hopefully brand new Greddy cat back exaust. |
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Won't work!
MR2 Rims = 5 bolt Yaris = 4 bolt
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
well thats super gay.
thanks for the info tho.
Cousin Vitz
No problem.
I also considered exchanging wheels within the Toyota line - I wanted the Celica GTS wheels but they're also 5 bolt.
this pic shows it having the 4 lug set up tho...
Cousin Vitz
Didn't know that!
This is what I found: MK I Toyota MR2 1986-1990 (4x100mm / HPO / 12x1.5 Lug-nut / 54.06mm Bore) MK II Toyota MR2 1991-up (5x114.3mm / HPO / 12x1.5 Lug-nut / 60.06mm Bore) So you can use MR2 wheels, but they have to be from the MK I generation.
Νο guys, yesterday I saw some MR2 rims and they had 4 bolts.
Cousin Vitz
Ok, now this is really confusing...
All of the MR2s (mark II mind you) I have seen, including my friends' is a 5-bolt pattern.
Cousin Vitz
Ok, to clear things up here.
MKI MR2 85-89: 4 bolt MKII MR2 89-99: 5 bolt MKIII MR2 99-06: 4 bolt Edit: I have confirmed this information with a friend owns a MKII SW22 MR2 and he also happens to own a MKI AW11 MR2.
MR2 S wheels..
well, here's a couple problems in 2000-2002 I believe.. the MR2 had 15's in 02-end of the line, the MR2 had 16's on the rear. ok next problem, they're different widths front to back, as well as different offsets.. here's a pic of MR2 wheels on my Corolla. keep in mind, they do FIT but not a very good offset.. ![]() ![]() so, final words, they will fit.. try and pick up two sets of rear wheels and get 16X7's :) i believe the 15's were 15X6 in front, 15X6.5 rear.. very very narrow |
Cousin Vitz
MR2 S = MR Spyder right?
If so, it would be classified as MKIII - so yes it would work.. I keep thinking that people want MKII MR2 wheels on their Yarii, so I keep saying no because they're 5 bolt..
Mine has mr2 spyder rims . rears are wider then the front. I got these back in Sept when I got the car.
![]() There is a pin on the rear wheels that need to be unbolted ( on the spyder wheels) |
nice wheels, tires are waaaay undersized..
#14 |
yes they are the stock mr2 tires. they were almost new when I got them. I will go with a little bigger tire when I wear these down some..
#15 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
well, i get the feeling that the mk1 older mr2 wheels will fit cause from what i have read they are 4 on 100, which is what our wheels are...the newer ones are 5 lug.
#16 |
It is clear now.
| FS Brand New Stock rims w/ Tires | FlintS | Items for Sale by private party | 10 | 09-24-2007 08:22 PM |
| Rims & Tires | riceboy | Items for Sale by private party | 19 | 11-25-2006 12:22 AM |
| New rims - old tires | littlecarlove | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 11-15-2006 06:51 PM |
| New Springs and Rims! | Lafiro | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 09-11-2006 10:26 PM |
| RIMS ON THE YARIS | Uglyboyed | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 06-26-2006 02:02 AM |
