#181 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
From my own experience, I would be inclined to say "impressively little" wear. Significance is relative. I tend to keep my cars a very long time. Like 20 and 40 years. (Call me sentimental.) And I dread overhauls. They always seem to result in some sort of complication. And, at the very least, expense... no matter how long the original lasts. It's possible that a certain amount of extra warm up might be beneficial over the very long run. Or... it could be, as you say, insignificant... even in my situation.
It's an interesting topic. Actually "topics", since we have two questions. How do warm ups affect fuel economy under different use scenarios? And how do they affect wear? I was planning on scoping out the easier of the two: fuel economy, this week. But surely Car & Driver, or Consumer Reports, or *someone* with better resources has researched these things. I just now got back from a long trip and am not too keen on a Google-hunt, sorting out all the credible wheat from the unreliable chaff. But I figured I'd mention. -Steve |
#182 | |
![]() Drives: 2008 Yaris 5spd, 2005 GLI 1.8T Join Date: Aug 2009
#183 | |
I don't think that this thread necessarily has to be a waste of time. It could be a good thread or a bad thread, depending upon how the participants handle it. 127.0.0.1 and I tend toward the "just drive it" opinion. You're the fellow carrying the "warm it up first" side. And that's a very reasonable view. But maybe it seems like we're ganging up on you or something. I don't know. I'm less concerned about right or wrong, or the winning or losing of an argument, than I am with what useful, helpful, or education information comes out of the thread. I'm wondering... where is the pivot point? How far or little can you push the throttle before wear per mile stops decreasing and starts increasing... or fuel per mile stops decreasing and starts increasing. -Steve |
#184 |
we drive from start up if possible . Depends if there's frost , ice , or snow on it .
#185 |
The ECO-METER shows good amount of fuel consumption when using the AVERAGE M.P.G. MODE if have to let it defrost thanks to higher idle at start ups and the tranny remains in 3rd gear until car reaches normal operating temperature ( blue light goes out )
#186 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
I'm in the drive easy until it warms up crowd. I give it a good 15 sec after I start it then drive very gently and keep the rpms down until it warms up. I clear the ice and snow before I start it. I do use a block heater when it's cold though.
R2 |
#187 | |
I'm wondering what the rationale is for locking out 4th at low engine temperatures. I tend to want the transmission to keep the RPMs *lower* when the engine is cold. -Steve |
#188 |
takes ours about 1 mile before it's capable of using overdrive . We drive under 40 m.p.h. to help keep the R.P.M.s down . Also try to leave the heater core on cold to cut off flow of antifreeze to speed up the use of 4th gear . Then turn on heat if needed . Figure less distance for coolant to travel letting the anti-freeze go around engine picking up the heat generated to help with quicker normal temperature operation so blue light disappears and idle drops sooner . Thus saving some fuel . Is a nuisance .
![]() Last edited by Hershey; 03-15-2010 at 01:04 PM. |
#189 |
since removal of 4 studded tires and warmer weather the 2010 3 door with auto is now getting 40 + miles per gallon . This is VALERO 87 octane ( 10% ethanol ) at 1 click of nozzle at full speed ( always same pump ) , tires set at 36 p.s.i. , 2 people , some headwinds of 25 + m.p.h. , and an average of 50 m.p.h.. Before were lucky to get 36 . Not sure if summer blend has reached our region as of yet , if not can possibly see more of increase
![]() ![]() Last edited by Hershey; 03-21-2010 at 11:40 PM. |
#190 | |
The heater on the Yaris can accurately be considered an auxiliary radiator. -Steve |
#191 |
#192 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
All the more reason to use a grille block in the cold months. I just took mine back out last weekend. I'll put it back in sometime in November or December.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#193 | |
As you know, I'm a sort of show-me-the-data kind of guy... so I'm not actually advocating this. But it is, at least, an interesting idea. Especially for perpetually cold climates. I assume that he already used a grille block. Funny... those fake louvres we see on some cars as decorations (Hi 1979 Lincoln Mark V! I'm thinking of you!) used to actually function, back in the day. The driver had a pull-knob to close them to facilitate warm up. Then again, the driver also had a choke pull-knob and an ignition timing pull-knob. Always remember to pull both of those before trying to start the car. Failing to retard the timing could actually be deadly to the person turning the starting crank.[1] But that issue was a bit earlier, back in the 1900s and 1910s. It was a fellow whose friend was killed in just such a timing/crank accident who invented the electric starter which Cadillac introduced in 1912. -Steve [1] Consider what happens when the timing is advanced before TDC. Last edited by sbergman27; 03-22-2010 at 05:07 PM. |
#194 |
Me too. This morning, I did run a test to get an idea how much (or little) fuel it actually takes to warm the engine to 128F (when the "Cool" light goes off), and to 140F, when the automatic transmission makes 4th gear and torque converter lock-up available. I found the answer to be a bit surprising. At an ambient temperature of 43F, it's only 0.03 gallons in both cases. (Scangauge doesn't go beyond 0.01 gal precision.) The "Cool" light went off just as the readout clicked over to 0.03. This is significantly less than I would have guessed.
-Steve |
#195 |
What?
Sounds insignificant when you put it that way. And for someone who puts a lot of miles on their car every day, it probably is.
My typical trip is 3-5 miles. At 40 mpg, that's an average of about .10 gallons per trip. If I let the car sit and warm up before every trip, I'd use 30% more fuel!!! (even if you only count the .03 gallons on the initial start-up, it still adds up to 15% of my total fuel usage on a typical day) Needless to say, I'm in the "drive it easy until it warms up" contingent. I get in the car, buckle my seatbelt, put the transmission in gear (manual trans), release the handbrake and check my mirrors all before turning the key. As soon as the engine is started I'm letting the clutch out and backing out of my driveway! Unless the air temp is fairly cool (below 60-65 degrees), the "cool" light is usually off after the 3rd stop sign in my neighborhood, just before I turn onto the main road. |
#196 | |
I'd just like to see more quantitative discussions. City driving *is* admittedly a lot messier, though. -Steve |
#197 | |
My *intuition* agrees with you. But my intuition could be as wrong as yours. We need to test experimentally. (My bad. I haven't gotten to it.) Otherwise, we're no better scientists than was Aristotle. -Steve |
#198 |
What?
I get what you're saying. Potentially, the fuel used to warm-up plus the first mile or so of driving a WARMED UP engine could add up to less fuel usage than driving a cold engine for a mile or so. Maybe in some super-cold climate this might be possible. I can tell you from my observations in MY climate (Florida, almost always above 60 degrees) using a ScanGauge that eliminating the warm-up gives me better results. I don't need to quantify it more than that for my own purposes.
I'm not a "pure numbers" guy. I understand the physics and usually have a grasp on the math involved, but I "live" the philosophy derived from it. |
Thread Tools | |
Display Modes | |
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan | kaboom | New YARIS Purchase Forum | 9 | 05-15-2007 02:58 AM |
Fuel consumption US Yaris vs. Canadian Yaris | Driver | Performance Modifications | 8 | 10-29-2006 02:27 AM |
