Old 03-15-2010, 12:47 PM   #1
fratzica
Diesel Inside
fratzica's Avatar
Drives: Yaris 1.4 D-4D
do you have any idea if this tutorial works on european Yaris models? Or if not, could you direct me to one? Thank you!
fratzica is offline   Reply With Quote
Old 03-15-2010, 12:53 PM   #2
It does not work on European Yaris, as they don't have the cruise control functionality built into the ECM. To add cruise control you would need to purchase an expensive aftermarket kit (I believe people have mentioned it to be about $800 USD).
Old 03-15-2010, 01:00 PM   #3
fratzica
Diesel Inside
fratzica's Avatar
wow that`s expensive
Did you also check the diesel European models, or just the gasoline powered ones?
Thank you for your quick answer.
Old 03-15-2010, 01:14 PM   #4
Both do not.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
