Old 03-15-2010, 02:05 PM   #1
goat1of2
Drives: 2008 Yaris LB Auto 3-door
Disaster! Car dead in driveway!
Well, as you can probably tell from the stupid questions I was asking, this mod was way way beyond me. I have now broken a part and am wondering if you would identify which Toyota part number it is (where do you find these numbers?)
It is the plastic locking lever which locks in and holds connector A21. Picture enclosed.
Also, I did another stupid thing which seemed smart at the time: I pushed the plug over Pin 40 down through the connector. Of course it didn't come out the other side. I was supposed to pull it OUT! Stupid stupid. Now my special 20.00 connnector orderd from Toyota will not seat. Any suggestions? Other than just shooting myself now.
goat1of2 is offline   Reply With Quote
Old 03-15-2010, 02:32 PM   #2
Yikes!
I don't see the locking lever listed anywhere in the EPC, so for that one you'll have to check with the parts person at your local dealer to see if it can be purchased (otherwise you might have to try to find one at a junkyard).
for getting that rubber plug back out, try pushing it from the pin side. If that doesn't work, you might be able to pull it out the wire side using a sewing pin with the tip bent into a hook.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
