Old 12-31-2006, 03:10 PM   #1
the.shau
the.shau's Avatar
Drives: 2007 Yaris LB auto
Send a message via Yahoo to the.shau
I have the same problem at a stop light that "Nutzoids" has...
what is that due to?
the.shau is offline   Reply With Quote
Old 12-31-2006, 05:12 PM   #2
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
The Marty McFly Effect!
There is another Thread on that issue... The RPMs rev at 600 on Idle, It saves gas that way!
Problem when the fan kicks on it drops a little and it gets to that "about to stall phase" Thats the reason it shakes, it's about to stall, but the ECU pulls it out right away... You can raise your Idle RPMs if you’d like, That would fix it for good... But you'll loose some of your Gas Mileage.
Otherwise its completely Normal!!!!
Nutzoids is offline   Reply With Quote
Rattle Causer in Rear? yaris-intuit DIY / Maintenance / Service 1 10-06-2006 06:56 PM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
