Old 03-16-2010, 07:24 AM   #1
goat1of2
Drives: 2008 Yaris LB Auto 3-door
Originally Posted by Sodium Duck View Post
I also did that with the rubber thing in the connector, too. Just take a needle and push it back out the right way, it'll go. I had a lot of trouble too with that stupid connector. That black sliding piece wouldn't go back on, and after 10 minutes of fudging around with it, I just took it off and put the gray piece back on and slid it into place.
Don't worry - your car is not dead.
Thank you, Mr (or Ms) Duck, for your kind words of sympathy. The boyfriend came home after work and somehow managed to reinstall the piece I'd broken and superglued back together. Car now runs. PHEW! Back to square one.
He tried for quite some time to work out that plug using a pin, a thicker piece of wire, and just some general cussing. He says he can see the plug down in there and it is kind of sideways, allowing a wire to go right through to the other side, without piercing the plug.
He wants to use a tiny drill bit and DRILL the plug to bits. I say we don't know what the heck is inside that connection hole, so we risk ruining a 500.00 component! We might just smear the material the plug is made of all up inside there, making a worse mess. We might somehow screw up the neighboring connector, which has a wire already in it.
I want to try leaving the plug in and just pushing a single-strand AWG 20 wire through the connector and seeing if THAT will make a good-enough connection. A wire of that description does go right through.
So, do we try it his way or my way? Or, do I just cover the hole left by the missing plug with electrical tape and pronounce this vehicle PERMANENTLY WITHOUT CRUISE CONTROL.
I hope at least you all are getting a good laugh out of this!
goat1of2 is offline   Reply With Quote
Old 03-16-2010, 07:50 AM   #2
I would avoid the drill bit route, as that has the potential to do unnecessary damage. The cavity that the plug is stuck in is rectangular, so it is fairly easy to have it round plug end of sideways in there. The drill bit will probably just chew up the soft sides of the cavity, rather than the plug. The key with the plug being wedged is to get something to hook deep enough into the plug to allow it to be pulled.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
