Old 03-16-2010, 11:38 AM   #1
Originally Posted by buffalogirl View Post
I have only had it on outside air, so I don't know if there's a difference in how strong the smell is.
Can I check to see if the smell is there 4 hours after shutting the car off, or do I have to drive it first and check right after? The smell doesn't always start right away (today it was about 10 mins into my drive), but I could go out on my lunch break and run it for a while to see if it starts to smell again.
Could the connection loosen just from driving around? I noticed the smell before getting my oil changed, but thought it was a truck I drove by.
Thanks for the help!
You could check it at any time, but based on your description, you probably have more of a chance of seeing something as or right after the smell occurs. Maybe do the lunch drive and then as soon as it starts to smell, pull over and pop the hood.
If things were properly tightened, they won't loosen just from driving. Perhaps your oil change people were looking for a way to increase their income from you...
Old 03-16-2010, 11:41 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Could be a leak anywhere in the fuel system.
If it were that vent hose I mentioned, the problem would be worse right after filling, but can occur anytime the pressure in the tank is above atmospheric, as when it warms up. I could see gas drip from mine after filling it to the top, which is a bad idea anyway as that can cause liquid gas to get pushed into the activated carbon evaporative emissions control canisters when the full tank warms up and pushes fumes and fuel out.
Old 03-16-2010, 12:05 PM   #3
buffalogirl
Drives: 2007 Yaris
Thanks guys! I'll check for leaks during lunch.
Couldn't have been them.. the first 2 times it happened were before the oil change, both times next to big trucks so I just assumed it was the trucks and didn't mention it to them to look at. I have heard of places doing stuff like that though... one place broke the pipe to the muffler on my friend's car while she watched and then tried to say it was like that when she brought it in. The place I go has great customer service and I've only heard good things about them... that's why I go there
buffalogirl is offline   Reply With Quote
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Coolant Smell after sitting in hot sun? Snappy General Yaris / Vitz Discussion 3 05-31-2009 12:18 AM
Getting used to driving small cars... orangepeels General Yaris / Vitz Discussion 19 05-06-2009 12:45 PM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 05:26 PM
