Old 12-31-2006, 07:26 PM   #1
jookybanana
1NZ-FE all day long
Drives: HS13, NCP91, GE8
i have 18x7.5 and 215/35/18 rubber, droped on df210 springs and it rubbed slightly for the first couple of days, but now its gone, it will wear in, and i checked the fender liner and its looks fine, no holes or heavily worn out parts
if you go 18x7 it probably wont make a difference since you will still run 215/35 tires, unless you have 205 tires, but i havent seen any for 18" except for toyo t1-r
i'm not sure if weight (big guys) would make a big difference, but i still daily on 18" and drive lots of people and it hasnt been a problem, i think any lower than spring drop there will be some problems, like coil-overs low
jookybanana is offline   Reply With Quote
Old 01-01-2007, 12:54 PM   #2
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
Thanks. Hearing your situation makes me think I'll be fine with the nf210's. I'm going to wait until my rims show up to make sure I still need to drop it though.
OgDogg is offline   Reply With Quote
Interesting Yaris coming to my local dealer... Goose General Yaris / Vitz Discussion 4 11-08-2006 09:39 AM
