Diesel Inside
Drives: Yaris 1.4 D-4D Join Date: Feb 2010
So this is what I found under the steering column in my EU spec 08` Yaris D-4D.
I have the brown and blue wires but both in the wrong pin locations. Sorry for the blueish color, i took the photos with my cellphone. |
Those are for the steering wheel radio controls.
![]() ![]() Drives: '07 Yaris 3DRH Join Date: Mar 2010
Tried this, Not working, HELP!
Ok Guys I tried this MOD today and it doesn't work. I used 2 NO Switches and 1 680ohm 1/2 5% cfr resistor, grounded to chasis at the drivers side door and hot to PIN 40 of the ECM. Jumpered the Clutch switch and took it for a test drive. NADA.
I'm wondering if the resistor may be the problem or if the problem could be that I used 20 Gauge solid and not stranded wire, (shouldn't make a difference I wouldn't think), to build the circuit and run the hot and ground. every thing checked and doubled checked, any Ideas? BTW, I am using the 2 switch method not the 4. |
#4 | |
How did you make the connection to pin 40? Solid vs stranded shouldn't make a difference, but with the 680 ohm resistor being near the top end of the range (567-693 ohms), if your 5% tolerance is off in the + direction, then you may be out of range for the set function. +5% on 680 puts you up to 714 ohms. |
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
