Old 03-18-2010, 04:02 AM   #1
Schizoprenia
Drives: Toyota Yaris 1.5 M/T '06
Hi NST,
i just want to enquire something. ur parts here in this side of the world isn't so common(Indonesia) i needed more information, if i have the Thai's built yaris, would i need a different set that is intended for the asian built ones? i know that waterpump doesn't fit right away but requires some sort of spacer if im not wrong, correct? can you please elaborate and maybe provide more information on the other crank underdrive as well as the alternator. thanks.
Schizoprenia is offline   Reply With Quote
Old 04-06-2010, 06:23 PM   #2
NonStopTuning
Originally Posted by Schizoprenia View Post
Hi NST,
Thank you for your interest in our site and products, we appreciate it.
I have posted this info several times in this thread, but will post for you again...
IFFF your 1.3 or 1.5 Yaris has a single-row (one belt) crank pulley, then you can order pulleys from our Yaris page on our website.
IFFF your Yaris has a two-row (two belt) crank pulley, then you will need to order pulleys from our Scion xA/xB page on our website.
Yaris 1.8L pulleys are also listed on our website on the Yaris and Scion xD page.
Thanks again, good luck and have fun with all your projects!
MIKE @ NST
www.NonStopTuning.com
