Old 03-18-2010, 06:29 PM   #1
bronsin
bronsin's Avatar
Originally Posted by sbergman27 View Post
If you are not planning on changing the fluid, I'd suggest leaving the filter, as well. I would expect the filter to gain efficiency over time, if anything. If it clogs (doubtful), you'll know it. Otherwise, it should be fine. Changing the filter means you'll have to drain the fluid into a container, pull the pan, replace the filter, and then pour the fluid back in. All this entails chances for contamination. And the factory service manual specifically says *not* to do that. It says to *always* use fresh fluid.
-Steve
Hmmm not doing ANYTHING AT ALL has a certain cache now that Im 54.
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
Two Millionth Toyota Sold in UK VitzBoy General Yaris / Vitz Discussion 0 03-06-2006 03:52 PM
