Old 12-31-2006, 08:06 PM   #1
ryker
Drives: Yaris liftback
How do I take apart dash on left side?
I'm trying to tap into the parking light wire on the fuse box which is a 30 pin on the upper left side. I can get the small cubby out in order to see the fuse box, but how do I remove the rest of the dash above the fuse box? Does it just pull out? I didn't want to force it and break something, the wife would kill me. I'm putting in a remote starter and I need a positive parking light wire, the one that comes off the headlight switch is negative. If anyone knows of another location I can tap into let me know.
ryker is offline   Reply With Quote
Old 01-01-2007, 12:19 AM   #2
ChinoCharles
Drives: LB
What you need to do is search the forums for the Yaris Repair Manual. That thing will tell you all you need to know.
Old 01-01-2007, 12:26 AM   #3
acrbill
Drives: Polar White Hatch
You don't need to remove the dash. Pull the 30 pin plug out find the wire and strip some insulation away and tap right in.
I tapped into all 3 door triggers, parking lights and the dome light wire without removing any part of the dash.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 01-01-2007, 07:58 AM   #4
ryker
Thanks acrbill. I had looked at pulling it out but didn't want to fudge anything up. That's what I will do then.
Old 01-01-2007, 12:29 PM   #5
acrbill
be careful with the wires since they are very thin. I used one of those automatic strippers and I broke most of the wires I was trying to strip.
Old 01-01-2007, 06:01 PM   #6
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
The best way (IMHO) to strip a wire with limited room/thin wires is "sawing" the plastic with a blade. The automatic stuff works for home installations and what not, but they make bad things happen to good people on thin wires :P.
TrancosRt is offline   Reply With Quote
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 04:59 PM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 03:40 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 07:10 PM
Removing A-pillar/partial dash H8SGAS DIY / Maintenance / Service 0 09-02-2006 10:03 PM
