Old 03-18-2010, 10:03 PM   #1
fiia
fiia's Avatar
Drives: 09 Flint Mica Sedan
Originally Posted by 1stToyota View Post
And +1 on the Amsoil; made a noticeable difference in mine. Tried GL-5 Lubro-Moly 75W-90 Synthetic Gear Oil prior to the Amsoil; the Lubro-Moly made no difference at all over the factory fill.
For the 75w-90 oils, can you mix these with the standard stuff Toyota puts in (10w40) or do you have to completely drain that out first?
also, at what mileage intervals is it recommended to use these?
I have about 15k but I often drive through heavy traffic on the highway and sometimes experience similar shifting problems, so I was looking to use redline. Any thoughts?
fiia is offline   Reply With Quote
Old 03-19-2010, 12:05 AM   #2
Hershey
drain and refill . Then use your choice of the REDLINE MT-90 or the AMSOIL MTG . These are GL-4 oils and you will encounter better shifting than with a GL-5 . Also less corrosive . Know from own experience with GL-5 and GL-4 gear oil . GL-4 is a must . GOOD LUCK
Any1 with Yaris Sedan and babies? boosta New YARIS Purchase Forum 4 01-07-2009 02:11 PM
Official Toyota Thailand accessories for Yaris Hatch & Sedan eTiMaGo Cosmetic Modifications (Exterior/Interior) 85 04-18-2007 07:53 AM
