Old 03-19-2010, 06:31 AM   #1
yaris2010RS
yaris2010RS's Avatar
Originally Posted by IllusionX View Post
^^ there's that.
but the canadian yaris.. and i believe the cold weather packaged yaris also, have an electric heater to help the interior warm up faster.
has anyone actually found evidence of this? lol. i've seen it around here but is it actually true? i find in my car, untill the little green COLD light (which i am not a great fan of) turns off i willl not get much of any heat
EDIT: and would we also not get a little bit of a toaster like smell. all electric heaters let off some sort of smell for the first little while
Old 03-20-2010, 10:47 AM   #2
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
Not sure, I wondered the same thing after reading about the electric heater on YW.
Is the cold weather package different than the all weather package? I just looked at my window sticker, and my "all weather guard" package has: Larger window washer tank with low level warning indicator lamp, heavy-duty heater, heavy-duty starter and rear heater duct.
BuildCode is offline   Reply With Quote
Old 03-20-2010, 11:02 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
That may be the source of the rumor, but a "heavy duty heater" isn't an electric heater.
Old 03-20-2010, 11:04 AM   #4
BuildCode
BuildCode's Avatar
That's what I had figured after going through a winter with no signs of electric heat. Is it a bigger heater core then?
Old 03-20-2010, 11:07 AM   #5
Yaris Hilton
Smile
That's my understanding.
Someone with time on their hands and a Toyota parts catalog could prove it easily.
Old 03-22-2010, 02:18 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
Mine does not produce much heat either until the light turns off :( Anyhow, i don't think we'll ever find evidence of it until someone actually takes the car apart.
Someone needs to grab the complete repair manual from a toyota dealer. I'll try to remind myself to ask for the heater core assembly diagram see what shows in there....
Old 03-22-2010, 06:36 PM   #7
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
I'd been assuming that evidence existed. But... a quick search doesn't turn anything up. I've heard that it's a ceramic heater. (Makes sense.) But a search of the FSM PDFs for "ceramic" doesn't return anything relevant. Neither does a search for "heater". Then again, I'm finding that the the FSM is more concerned about the acceptable pulse-width of the signal from the wiper speed sensor than it is about... you know... things that are actually, physically important for the functioning of the car. Things made out of metal rather than silicon. Like pistons, brake rotors, and heater cores.
The utility of an auxiiary electric ceramic heater is dubious. If you look around at various highway travel stops (e.g. Love's) you can find 12v, 15 amp electric heaters that plug into the 12v outlet. They draw between 150 and 200 watts, and are fairly inexpensive. So you can easily judge for yourself. They put out a *barely* perceptible stream of sorta warm air. If the Cold Weather Package built-in version drew 50 amps(!), that would be about 700 watts at 14 volts and *might* make a slight difference. (And why are we still using 12v electrical systems in the year 2010, I wonder?)
-Steve
sbergman27 is offline   Reply With Quote
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
