Old 03-19-2010, 09:17 PM   #1
Hey Scott, is it suppose to only turn on when the doors are opened, and don't turn on when the dome light is set to on? That's how mine is acting, and I just installed some LED strips on my gf's Civic, and her's does the same. Any way to have the strips turn on when the dome light is switched to the on position as well as when the doors open?
Yes, when you connect it under the dash, you either get always on or, switched with the doors. To have them switched with the manual switch on the dome light, you'd have to get a wire up to the dome light switch.
Old 03-20-2010, 02:26 AM   #2
Dang. I might just get a switch and redo everything. Get the positive to a constant power and place a toggle switch somewhere hidden. I'm thinking this is more than I can do on my own, so I'm going to have a friend help me out this time and learn so that I can redo my gf's Civic. Thanks for replying, Scott.
Old 03-20-2010, 07:41 AM   #3
Buy a single pole dual throw switch (SPDT), and then you can use it to switch the ground leg between the door input and the chassis ground. That way it will act just like the dome, but with a separate switch for the constant on mode.
Old 03-20-2010, 02:42 PM   #4
Which one is the chassis ground? How would I connect the two grounds to that switch?
