Old 03-19-2010, 10:23 PM   #1
weaver615
Drives: '07 Yaris 3DRH
Scott, just replaced risistors with 2 330 ohm resistors, still nada, resistance at 630 well with in the band...I am perplexed....now what?
weaver615 is offline   Reply With Quote
Old 03-20-2010, 09:34 AM   #2
Take pictures of everything - Switch wiring, clutch switch bypass wiring, ECM connection point.
Old 03-20-2010, 04:22 PM   #3
weaver615
2007 YARIS 5 SPD MT DIY CRUISE CONTROL
ok here are pics of my DIY cruise control on a 2007 Yaris 5 speed Manual transmission.
PIC 1: switch with circuit Used 680 ohm resistor. Splice in place after redoing circuit. Red wire to PIN 40 on ECM Black wire to ground at drivers side door.
PIC 2: ECM with Red wire at PIN 40.
PIC 3: Clutch jumpered at fuse box done using nickhjort's method.
PROBLEM: Cruise doesn't work. ON/OFF swtich doesn't seem to get power. SET doesn't engage.
HYPOTHESIS: Either bad switches (second set), or ECM doesn't support Cruise Control.
Where do I go from here?
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
