Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-24-2010, 08:18 AM   #1
Cortland Yaris User
Drives: Yaris Liftback 08 Bayou Blue
Mga pre... just wanted to say hi to everyone... long live our kababayan all over the world...
Cortland Yaris User is offline   Reply With Quote
Old 03-24-2010, 09:00 AM   #2
syntax
syntax's Avatar
@rye naalala ko nga pala dati nagtanong ako ng sony HU at 2speakers at subs, plus amp, 1.5K, sa pagkakaalala ko ha, pero baka bago na ang presyo ngayon, sa ABS naman parang pagkakaalam ko ay standard na ang ABS
@cortland, hello din kabayan, kamusta na ang buhay buhay sa tate'?
Old 03-24-2010, 09:48 AM   #3
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax: kailan ka nagtanong? sa sony center ba mismo? tsk! gusto ko yun! hehehe..
@cortland: nice to hear from you kabayan. baka may mga tips ka for us newbies here in yarisworld. we're planning to change our rims and wheels and add some rear sway and strut bar. peace!
rye7jen is offline   Reply With Quote
Old 03-24-2010, 12:45 PM   #4
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
mga kabayaan share ko lang Tungkol sa ABS sa pagkakaalam ko pag manual walang ABS anti locking break tsaka EBA electronic break assist.ang may ron ABS yaris Y tsaka YX,yaris sport malalaman mo pag may abs ang yaris mo pag susi mo sa dash pannel may ABS naka indicate.
funtion ng ABS pagtapak mo ng preno sa malapit na sasakyan di siya agad mag lock may chance kapang iiwas pero pag wala didikit na ang tire mo mag slide na di na ka makakaiwas lalo na dito sa riyahd medyo madulas ang daan.
amaze_2 is offline   Reply With Quote
Old 03-24-2010, 12:52 PM   #5
trebparadise
Drives: sedan yaris y
Here's more info about ABS.
ABS stands for antilock braking system, which is a safety feature that prevents wheel lockup and skidding during emergency braking. Antilock braking systems pump the brakes up to 20 times per second, allowing drivers to keep control of the vehicle during an emergency braking maneuver.
On older cars — or any car without antilock brakes — you should pump the brakes in a crude attempt to prevent skidding. Antilock brakes do a quicker and more precise job of pumping the brakes than a person ever could. If you’re driving a car with antilock brakes and have to make an emergency stop, it’s recommended to stomp on the brake pedal, hold firm pressure and steer out of the way if needed.
Antilock brakes have a unique feel when the system is activated; the pedal usually pulsates very quickly, so don’t be alarmed if this happens during emergency braking; just keep your foot planted.
Antilock brakes are available on just about every new car; if they’re not standard equipment, they’re generally not an expensive option.
trebparadise is offline   Reply With Quote
Old 03-25-2010, 03:32 AM   #6
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Ok. I think tapos na ang issue regarding sa ABS feature ng yaris.
According to the site www.toyota.com, these features are all included on all packages of Toyota Yaris:
Warning lights: seatbelt disconnect, airbag [1], door-ajar, battery, oil pressure, brake, Vehicle Stability Control (VSC)[2]-off [3], Traction Control (TRAC)-off [4], ABS, Direct Tire Pressure Monitor System (TPMS) [5], check engine, scheduled maintenance and low-fuel-level indicator
As I remeber, toyota made these features included on all packages of yaris in 2010 models, not sure if 2009 models are the same.
You can visit their site or see the image i had attached.
Name:  Toyota Yaris -- 2010 Models_ Liftback & Sedan_Page_1.jpg
Old 03-25-2010, 03:33 AM   #7
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax safe pa rin tayo.hehehehe!!!
Old 03-25-2010, 03:39 AM   #8
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@treb baka pwede ka rin mag-attach ng mga pics ng Audio system mo pag may free time ka para may idea rin kami pano gawin. Thanks!
Old 03-25-2010, 02:43 PM   #9
trebparadise
@rye, Ganito lang ang sub ko, d ko na binago ang speaker system ng yaris natin, i just add this one to give more base. kung gusto mo dalawahin mo ang sub and get an input signal for sub on L/R rear speaker kasi ganun ang nakikita ko sa ibang car, kaya nga lang mas malaki ang battery ng car nila. d nga lang gaanong pang Audiophelis ang dating nitong sa akin pero ayus na rin naman. lalo na pag tinugtugan ng Hiphop music ng panganay ko.
Old 03-25-2010, 04:04 AM   #10
syntax
syntax's Avatar
@ rye yehey! kapag may time ka pasyal ka batha dami dun mga audio accessories, indi naman kasi ako masyado inclined sa audio systems, more on performance ako.
mga kabayan, ano pa mga mods nyo sa yaris? bukod sa mags at tires nyo?
Old 03-27-2010, 02:10 AM   #11
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@treb: astig!! Ganitong ganito din ang gusto kong setup, mga magkano nagastos mo including na din yung box ng sub?
Ayos din yung floor mat mo, kasama ba yan sa package nung binili mo?
Old 03-27-2010, 05:46 AM   #12
syntax
syntax's Avatar
@treb nice setup pre, simple pero ayos ! magkano nagastos mo?
Old 03-27-2010, 10:41 AM   #13
trebparadise
Salamat nga bosing! wala pang SR300 ang nagastos ko, yung Sub SR250 lang sa pioneer showroom. Mas maganda lalo kung original na CD ang papatugtugin nyo. mas maganda ang quality ng music at base. at yung floormat naman kasama yan sa package. actualy yang floormat, plastic sya.
Old 03-30-2010, 08:26 AM   #14
bluecris44
bluecris44's Avatar
Drives: Yaris Sedan 2009 - "Angel"
Send a message via Yahoo to bluecris44
Hello mga Kabayan!
Newbie lang po ako d2 sa group na to... it's nice to be here... dami ako ng nakukuhang info... di pa kasi ganun kadami alam ko sa makina ng sasakyan eh... :)
Question lang po... may idea po how much will be the estimated cost pag nagpaupgrade from manual to power window including ung side mirror?
Thanks po...
Astig talaga tong site na to... sana nga magkitakita tayo minsan. \m/
bluecris44 is offline   Reply With Quote
Old 03-30-2010, 08:41 AM   #15
syntax
syntax's Avatar
@bluecriss welcome sa site pare pareho lang tayong newbie dito, nice to hear marami ka rin nakukuha info dito,
ano current setup/mods mo sa car mo?
sa nag set up ng keyless entry namin ni pareng rye, naitanong ko sa kanya sabi nya nasa 1.5K daw ang 4 windows ( paki verufy nga pareng rye kasi parang ang laki eh)nasa batha ung installer namin, ibang lahi nga lang pero trusted na kasi dami na referal na mga kakilala.
Old 03-30-2010, 10:28 AM   #16
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Hello bluecris! Welcome. Pare-pareho lang din tayong newbies dito. As for all of us, marami ngang write-ups and tips na mapupulot dito sa YW.
@syntax, rinig ko nga 1500 ang price nun. Nandito n pla yung filipino n kakilala ko sa toyota. anytime soon immeet ko siya for some inquiries. I'll post some of the info pag magkita na kami.
Old 03-30-2010, 03:48 PM   #17
trebparadise
Welcome to yarisworld Bluecriss44!!!
Old 03-30-2010, 04:16 PM   #18
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
Good day mga Sir...
Napapasyal pala ako dito sa Toyota Showroom - ALJ d2 sa Khurais, Nassem. Regarding sa mga available MODS sa Yaris natin, FRONT SPOILER (CHIN) SR 934 sya wala pang charge sa kabit, SPOILER SR 1800, SIDE SKIRTS & REAR SPOILER coming pa lang daw, hindi pa available sa kanila, kita rin nila sa ibang showroom d2 sa Riyadh kung saan may stock. Paki check ko na lang daw next month or kung kailangan ko raw i-oorder pa nila, waiting time mga 1 month - from Japan daw kasi.
Meron din EXHAUST TIP SR 180 sya at Wood Panels (almost SR900 sya sabi ni sadik - complete set). May Yaris din ang mokong (ibang lahi) at member din d2 sa YW. Empleyado sya dun kaya updated sa accessories. Dun sya mismo sa accessories section, sya tao dun.
Sa RIMS naman SR1000 to SR1200 ang range sa size 16", china pa yun! Bawas lang tayo ng konti kung size 15". BATHA price pala ang mga ito, SR2000 package kasama goma. GASTOS!!! baden....
Na-i share ko lang to-its, baka may alam kayong mas mura mas okay diba? Sa batha marami duon, hindi ko lang sigurado kung sino sa kanila yung totoo - alam nyo yun? May pulido gumawa at meron basta makabit lang 'KALAS SADIK"... kaya extra ingat lang kung hindi rin lang KABAYAN yung gagawa.
jon
jonimac is offline   Reply With Quote
New Yaris owner mySUV California 8 06-29-2010 01:29 PM
HAI guys! I'm new but not a yaris owner... Saskatchewan17 New YARIS Purchase Forum 4 10-12-2009 03:54 PM
