Old 03-22-2010, 10:37 PM   #1
Vb2ner
Team VAJJ
Vb2ner's Avatar
Drives: 2007 Yaris sedan Flint Mica
Yeah, the xxr's look good man! they rub though, don't they? Are they +15's?
So I honestly don't see how the spring install could be linked to that, because as I said, the angle of the axle could not have been bad enough to break it, and it obviously is not due to you not installing the suspension properly.... I would say it was probably on it's way out due to prior stress? How long have you been lowered? Faulty part perhaps? Either way, suck it up, get a new axle, and enjoy the stance:)
2007 Yaris Sedan DD, 95 VW Jetta boosted and laid out...stretch and poke FTW
Vb2ner is offline   Reply With Quote
Old 03-22-2010, 11:55 PM   #2
wholenizz
wholenizz's Avatar
Drives: 07 yaris hatchy
they are 16's and thx.
wholenizz is offline   Reply With Quote
Old 03-23-2010, 12:23 AM   #3
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
You don't need needle bearings, you need a CV joint, cv boot and bands. But then you would need special tools to remove and replace it from the half shaft (talk about a PITA) and a special tool to clamp the band back onto the boot.
Best bet is to replace the half shaft it's easier and most likely about the same price as a single CV joint with boot, bands and grease.
az_saguaro is offline   Reply With Quote
Old 03-23-2010, 07:21 AM   #4
Vb2ner
Team VAJJ
Vb2ner's Avatar
I meant offset, not rim size, and -15,hehe
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Progress Lowering Springs vs Tanabe DF210 lowering springs jyfro_13 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-24-2010 02:38 AM
FS: Progress lowering springs Cvc9216 Items for Sale by private party 0 10-23-2009 07:41 PM
2006 Toyota Yaris 5dr. LiftBack Lowering Springs yaya Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 05-14-2009 01:38 AM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
