Old 03-23-2010, 09:55 AM   #1
Rick
Drives: '08 Yaris LB 5M
Does it matter? To a Federal Bureaucrat it matters. To me, ..... I just disabled the TPMS and have no sensors at all in my aftermarket summer wheels. My winter wheels still have them but they are just useless rotating mass now.
Rick is offline   Reply With Quote
Old 03-23-2010, 10:36 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If it doesn't bother you to have that low tire pressure warning light constantly lit, and you'll keep your tire pressure checked regularly, it's no biggie.
Old 03-23-2010, 03:10 PM   #3
fiia
fiia's Avatar
Drives: 09 Flint Mica Sedan
how did you disable your TPMS? I'm looking for a solution to end once and for all the constant tire pressure light. I didnt get the sensors installed on my after market rims..and don't want to deal with the light anymore
fiia is offline   Reply With Quote
Old 03-23-2010, 03:17 PM   #4
http://www.yarisworld.com/forums/sho...iy+tpws&page=7
Jump right to post #115
Old 03-23-2010, 03:39 PM   #5
fiia
fiia's Avatar
so, in a nutshell, just cut the brown wire?
i read your original post then the pg 3 info w/ all the parts from radio shack...post 115 just looks like the brown wire was cut and tied to the white wire #6. is this correct?
and if so, what did you use to connect the brown and white wires?
Old 03-23-2010, 03:45 PM   #6
I went through a couple iterations of the mod and then one day realized that the simplest method was what I drew in 115.
You are correct with simply cutting the brown and connecting it to the white. You can use a simple tap splice connector to do it (available from any autoparts store).
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 08:01 PM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 03:57 PM
