![]() Drives: 2008 Polar White Yaris Sedan Join Date: Mar 2010
A handful of extremely NEWB questions
ok - so i'm about to start shopping for the cheaper mods. i'm looking at air filters, fog lights, and a wing type dealy for my trunk
i have an 08 sedan - i'm seeing both flat air filters and round ones. i already know i need a flat one because i've opened the housing and seen it. i assume the round is for an added intake, but i just want to be sure...? - i have a choice between AFE and K&m...is there any reason to pick one over the other? - does replacing oil filters do anything for performance? if so, which one should i get? - when i first start him up in the morning, and get going, it feels like its struggling to pull off...kind of sluggish, almost like a parking brake is on but not that intense. any mods to remedy this? sorry for the dumb questions but ya gotta start somewhere |
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback Join Date: Jan 2010
#4 | |
I love momentum.
2. If you're going to stick with the OEM airbox, stick with the OEM filter. I don't think any of the drop-in filters make any significant performance difference. The only other advantage is the fact that they are reusable, but even that doesn't seem to make them worthwhile (in my opinion). 3. Oil filters likely make no difference. I'd stick with OEM or whatever other type of filter you like. 4. Just because the air temp isn't cold, doesn't mean that your motor isn't "cold". Motors and transmissions take a little bit to warm up. That's likely why the car feels a bit poky when you first turn it on |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
any aftermarket air system is all about the same. it just depends on how much you wanna spend. i'd look in the for sale sections and buy the cheapest one or one that just happens to come up. it's all aesthetics, tehy all add the same amount of power, and they're all designed just about the same.
oil filters will not increase performance |
thank you all. i think ill just focus on my fog lights and wing for now then
#8 | |
pretty sure a pulley will be in my next set |
#9 | |
An underdrive as opposed to what? The NST CR Lite, the complete NST set w/ WP and ALT, or something else entirely? I went with NST UD based on reviews and resale became available from another member. I didn't really want the 3 piece set as the 'bang' comes from the crank pulley. The other two are little more than cosmetic mods. Didn't need the CR Lite since I'm not s/c'd, nor do I have high electical power drains.
When i googled "wing type dealy" on google images, this is the only car related pic that was on page one. Therefor, I now demand that you put this exact "wing type dealy" on your car.
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
#11 | |
lol...i will do no such thing. "spoiler", is it? lets roll with that instead... thanks for the oil filter info @ WeeYari, i meant the 10% underdrive as opposed to the cr lite or wp lite |
One more thing, specific to the oil filter question...
Oil filter co's always tout their micron filtration, flow rates,etc...On an enhine this size with such a weak oil pump, it won't matter, so go with whatever you want. I personally prefer FRAM, but that's just me, and that's because the bottom two inches is rubber dipped to make gripping the damn things easier. However, in high horsepower applications it can make a difference. I have literally seen an oil filter implode because of the vacuum created from the oil system that was being run, but this was on a big block nitro rail, not a yaris. My point is that yes, it can make a difference, but not on a yaris.
the 10% underdrive changes drive ratio, whereas the lite pulleys are same size, just lighter to make engine spool faster.
awesome, thank you
| new system tech questions | ryota | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 07-30-2009 05:09 PM |
| Going to Dealer, questions on options. | ejaf | New YARIS Purchase Forum | 24 | 11-19-2008 03:05 PM |
| Questions, questions... | littlecarlove | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-21-2006 02:42 PM |
| new owner.. have questions | chibianh | General Yaris / Vitz Discussion | 8 | 05-14-2006 12:44 PM |
