Old 03-23-2010, 12:49 PM   #1
I don't like having the TPMS as it is. But wouldn't it be cool if it would give you a readout of the actual pressure in each tire?
It would - They report pressure and temperature, so it would be very cool to have a live display of both for each tire. One of these days I'll figure out the protocol for the Yaris TPWS and make a device to do so. Crashy will be my test platform, since she has my 09 steelies with the sensors. Both of my sets of alloys that I run on my 09 are sensor free.
Old 03-24-2010, 01:02 PM   #2
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
So... would this be something that could be done via the Scangauge II's XGauge feature? Xgauge allows you to send arbitrary queries to the ECU and display the response, scaling and/or offsetting it as appropriate. Essentially, it allows you to define arbitrary new gauges. That really would be quite slick.
-Steve
sbergman27 is offline   Reply With Quote
Old 03-24-2010, 01:08 PM   #3
-Steve
No. From what I've found with things like turning off the seatbelt chime via can message to the cluster, you need to send more than one command, and the Xgauge mode only supports sending one packet.
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 08:01 PM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 03:57 PM
