#1 | |
Jump right to post #115 |
#2 | |
![]() Drives: 09 Flint Mica Sedan Join Date: Feb 2010
i read your original post then the pg 3 info w/ all the parts from radio shack...post 115 just looks like the brown wire was cut and tied to the white wire #6. is this correct? and if so, what did you use to connect the brown and white wires? |
#3 | |
You are correct with simply cutting the brown and connecting it to the white. You can use a simple tap splice connector to do it (available from any autoparts store). |
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 02:00 PM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 09:33 AM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 12:18 AM |
| 15" TPMS friendly wheels for my '08. Ideas? | auxmike | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 12-08-2008 08:01 PM |
| TPMS | TinyGiant | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-22-2008 03:57 PM |
