Old 03-23-2010, 03:23 PM   #1
weaver615
Drives: '07 Yaris 3DRH
UPDATE: DIY Cruise Control working fine. CTScott, I was wondering if would be possible to add JUST a RESUME switch to the 2 switch method? I was driving to work today and got to wondering this....Is it possible?
weaver615 is offline   Reply With Quote
Old 03-23-2010, 03:40 PM   #2
Sure - That would be the 3 switch method...
If you look at the picture below, from my original DIY, if you added a third switch, you would gain resume (and would then have + and -, since they are secondary functions on the set and resume switches)
You could parallel it to your existing rig using a 240 ohm resistor, or redo your switch wiring and just leave off the cancel switch.
Old 03-23-2010, 06:10 PM   #3
weaver615
3 SWITCH CRUISE CONTROL
The 3 switch DIY criuse control would be wired like this I believe. Am I correct in assuming this is right? Please excuse the art work...I did this in Paint so it isn't the greatest.
Old 03-23-2010, 08:05 PM   #4
Correct
Old 03-26-2010, 06:35 PM   #5
lily
lily
Drives: white plane jane
ok now...i need some help.
well, i've installed a wire with the connector tip, into PIN 40 of the ECU harness.
i've also made the 2-button style controller, just as the illustrations from the previous posts.
and...still no avail.
i have tested out the on/off buttons with a DMM and it reads about 5.24 when pressed and the ignition turned to 'on'. having the key to 'on' and no pressing the button, i get 0 on the DMM.
I NEED HELP TROUBLESHOOTING!
i think that the wire into PIN 40 is not contacting inside the ECU or the buttons are no good. i have the radio shack 275-1548 SPST 'Mini' buttons with a 125 VAC, 0.3amp @ 50 VDC. <<< ARE THESE BUTTONS GOOD ENOUGH TO MAKE THIS WORK???
i've already checked the single resistor to be about 634. <<< Is this OK?
out of ideas no, HELP!!!
lily is offline   Reply With Quote
Old 03-26-2010, 07:06 PM   #6
The switches are your issue. Those are normally closed (N.C.) switches, so they act like they are pressed until you press them, then they act like they are not. Radio Shack does not do a good job with labeling their switches.
You need normally open (N.O.) ones. 275-1571 are mini N.O. ones for example.
Old 03-26-2010, 08:00 PM   #7
lily
lily
AH HA!!!!!!!!!!!!!!!
upon further 'inspecting' the descriptions on the baggy, it does indeed say (in very fine print) "N.C. contacts". <<< I assume this is the "normally closed" which i need "normally open".
tomorrow i will have to go get the ones stated then.
i appreciate the help CTScott.
tune in...
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
