Old 03-23-2010, 03:39 PM   #1
fiia
fiia's Avatar
Drives: 09 Flint Mica Sedan
so, in a nutshell, just cut the brown wire?
i read your original post then the pg 3 info w/ all the parts from radio shack...post 115 just looks like the brown wire was cut and tied to the white wire #6. is this correct?
and if so, what did you use to connect the brown and white wires?
fiia is offline   Reply With Quote
Old 03-23-2010, 03:45 PM   #2
I went through a couple iterations of the mod and then one day realized that the simplest method was what I drew in 115.
You are correct with simply cutting the brown and connecting it to the white. You can use a simple tap splice connector to do it (available from any autoparts store).
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 08:01 PM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 03:57 PM
