Old 03-23-2010, 08:40 PM   #1
The passenger Occupancy ECU is located right under the front of the passenger seat. It has two connectors plugged into it. Like TK said, check them. If neither is loose, check the 4 connectors up under the four corners of the seat. If that's not it, reply back and I can walk you through having the SRS system flash its light to tell you why it's not happy.
