I love momentum.
Hard wired USB charge port?
Rather than use a cigarette lighter USB charger, I'd like to hard wire a USB port (or two) into my Yaris console. Has anyone found a clean solution for this? Something that you can flush mount to a flat panel would be great. I'd like the output of the port to be 1A (1000mA).
Thanks all! -S |
Not really here...
Drives: 2008 Blazing Blue S hatchback Join Date: Oct 2008
I'm just going to get a different head unit for my car that has a built in one. Like this one from Pioneer.
http://www.pioneerelectronics.com/PU...rs/AVH-P3200BT
Liberate Tutemet Ex Infernis. |
#3 | |
I love momentum.
#4 | |
Sorry electronics is not my strength.
I love momentum.
You can, yes, but I'd like a slightly "cleaner" install. I'm also not sure what sort of amperage that would push to the connector. Maybe CTScott will chime in and enlighten us :D
![]() ![]() Drives: 2 Yaris Hatchbacks Join Date: Dec 2006
Again, not quite what you asked for, but pretty unobtrusive:
Belkin Micro USB Charger (flush fitting lighter socket.) http://www.belkin.com/IWCatProductPa...duct_Id=489424 |
#7 | |
I love momentum.
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#9 | |
I love momentum.
Not really here...
There are different head units that are cheaper that I have seen with a USB port.
I love momentum.
Audio Junky
take a look at the fuse for the cigarette lighter for a clue as to if a 1 amp charging source is possible. If the fuse is 1 amp, you should be able to draw 1 amp from it for an hour or two without a problem. If the fuse is greater than 1 amp, you should be able to draw 1 amp from it with no problems at all.
You could always wire in your own fused circuit using 12awg wire, which would be good for say 20 amps if you wanted. You could then run any additional items off that in the future too. www.partsexpress.com has one right now for $2.50 then you just have to search through a compnay like www.digikey.com or www.mouser.com to find a surface mount female USB port. i'm sure if you did a google search for the pin outs for a USB port you could find instructions or an image that would show which each contact does. I once knew what they were... I want to say that they are 5volt & 7volt lines usually, but not positive... make sure that your device you are charging can accept 12v in, you wouldn't want to run a 12volt circuit to a device that could only handle 7v. |
I love momentum.
Thank you talnlnky, that was very helpful! The "surface mount female USB port" is the keyword I was looking for. If I can find that I can wire up the rest.
Getting warmer: http://www.amazon.com/Cable-Waterpro.../dp/B000AA85BG |
| DIY Powered USB Ports | BailOut | DIY / Maintenance / Service | 27 | 02-22-2017 10:17 AM |
| YARIS/VITZ 2006 - USB Connector on Dashboard or Console | jojozep2008 | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 04-19-2011 11:41 AM |
| DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS | julienrl | DIY / Maintenance / Service | 1 | 08-31-2009 10:06 AM |
