Scubie Du
Drives: '10 SWP STi/'09 Escalade Join Date: Nov 2006
if i am thinking about an engine swap - from 1.3 to 1.5 - please help
hi there
when i bought my yaris, i wasn't thinking about performance at all but now i started to think about and there is no parts for the 1.3 so if i think about the engine swap to 1.5L how much will it cost me (roughly speaking) and what parts other than the engine have to be changed? regards, Ashraf |
you'd need ECU for sure..
i say go Diesel D4D |
Diesel for sure!
Scubie Du
why diesel?
and please some bode tell me about the 1.5 swap price |
Diesel engine seems to have quite good performance and very low fuel consumption.
As for the engine swap, I really do not think anyone has done this one before, the engine itself should not be too expensive if you find one, but I am sure labour will not be cheap!
i can tell you this for sure:
you can do the swap in a day.. i know because i've done it myself on the xA. |
Scubie Du
so what are the suggestion
does the diesel engine have good accessories for it the 1.5 seems to have every thing u think u wanna change |
Roar?
how much preformance are you expecting to get out of the car even if you go with the 1.5 the only upgrade that will make a real noticable upgrade in hp would be a turbo or supercharger and you wont wanna do that without upgraded internals and if you plan that plan on opening your wallet a little wider lol
Scubie Du
I think i will just stay with the 1.3L after all, and modify the ext. & int. only
thanks guys for the advice |
Parallel Parking Pro
Yes, do that, 200cc of displacement gives a bit more grunt but not so much that it is worth the trouble. I have the 1NZ-FE and the engine is pretty dull in the workmanlike way with which it goes about its business. Its smooth but its got little by way of character. Its really not a performance-tuned engine, so you're not gaining so much more.
What I've heard about the 1.3 is that it isn't such a bad engine, you just need to rev it more to get to the power, and the good thing is, it likes to rev. The lower fuel consumption also helps make it easier for you to open the taps. |
+1 from me!
Personnally, if my car(1.3lt) was totally mine, I would add a turbocharger!
If I was to even atempt and engine swap I would try the 1.8L corrola engine... 100kw in such a small little car that weighs nothing.
just out of curiosity from reading over this thread;
ALL diesel engines which leave the factory, never mind the model seem to be extremely de-tuned. Ive seen what must be a hundred different engine tuners, parts etc for diesels which increase the ouput by ridiculous amounts. Anybody think this would hold true even on the little D4D? If its running at even the same power output (or even slightly less) would it not be possible to 'tune' it per se with the same power percentage increases as larger diesels? Keep in mind Ive never owned, run, or worked on diesels.
http://www.cardomain.com/ride/2336679 |
#14 | |
Definitely something for our european brethren to mess around with
#15 |
theres a guy here, cant remember the name of the shop but I did the drawings for his building.. anyway, he builds turbos for diesels, even has some patents on some of his parts. He has a Chev. 4x4 pushing 1000lbs out the wheels and about 450hp. Aparrently according to this guy and others Ive heard using diesel turbos on gas engines is common, perform better and last longer. I cant imagine there would be much more complication adding the turbo to a diesel...
All I could picture when the D4D came up was a Yaris pushing like 150hp and 500lbs/ft.
#16 | |
But with the right gear ratios that could actually be a real monster for drag racing
| Engine Swap | Nutzoids | Performance Modifications | 42 | 10-01-2007 06:20 PM |
