#37 | |
Audio Junky
I wasn't talking about what the correct way to set gains/signal processors was... tho, I read your comments.... and understand what you say... but generally would still go with bigger amps, and a more purist approach to avoiding clipped signals. the Overlap approach, seems pretty much like a good approach at compromising between sound quality, and the price of buying more powerful amplifiers. Think of it this way, you can split a circular pie in exactly three even pieces, but you can't perfectly find out what percent each piece of pie takes up. In math when you divide 1 whole by three, there is only one exact answer and that is 1/3. Often times people will say that it would be .3 or .33 or 33% or even .333 with the bar over the top of it that represents the number will continue on into infinity. .33 is not the same as 1/3, 33% is not the same as 1/3, .333 with the bar/line over the top still is not even 1/3 Yes they are very very similar... but there is a margin of error. The scope is the same way, the signal will ALWAYS start to clip before you can actually detect it using the scope. Now, if you do even a mediocre job it will still be better than what you can do by using the human ear as a test tool. So, it's kind of a semantic point, but that is why people always find the clipping point, and then dial back one or two clicks on the deck, amp, or signal processor. |
#38 | |
Audio Junky
The way I do it, is to figure where my port will be, so if its on the left side of the box, then goes to the back, then takes a 90degree turn alongside the back wall to the right. I take a straight edge, and draw exactly where my port walls will be. I then find the exact center of the port, and draw another line. When you are done, you should wind up with two L shaped marks on your box. the line that passes through the center of the port is the line I would use to do the measurements... (for you 11.65 inches long). I do remember that boxes that are designed off of wavelengths like transmission lines, every turn you do have to re-adjust for.... but wavelength based boxes often have a half dozen or more turns... which add up to a significant correction factor. To sum up, I believe you are supposed to do some correction for every turn, but not sure, As for walls.... I don't think it matters for walls. I would be more concerned with the displacement of the sub & internal bracing than I would be of the correction factor of a single turn. |
#39 |
![]() ![]() Drives: 07 Polar White Yaris Hatch-3DR Join Date: Jul 2006
never mind i got it planned it another way i will be making one turn and you are correct the correction factor only makes a .56 hz difference according to bass box. lol ... im making a wood / fiberglass box .. one last question now im looking at port velocity and i cant go any bigger area with port because length is not feasible is a 22 m/s speed ok. i see recomendations online to try and keep it below 18 any ideas.
#40 |
Roadrunner Jr.
Hey Taln, what about using bigger amps AND level matching? :)
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#41 | |
Audio Junky
Make sure that you put in your actual wattage in that port velocity chart... the velocity will change alot from say 100watts to 400watts. isn't that what I said???? oh gosh.... |
| Help choosing Razo Pedal Cover | wingdood | Cosmetic Modifications (Exterior/Interior) | 0 | 05-08-2009 11:39 PM |
| Help with choosing Amp kit | myt | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 01-20-2009 02:00 AM |
| Need to change my Sub, give me hand choosing the new one!! | mledez | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 01-11-2009 12:50 PM |
| Whats most important when choosing wheels? | cdydjded | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 06-01-2007 10:33 AM |
| Hard time choosing color; dark colored cars absorb more heat?? | fantabulousbaby | New YARIS Purchase Forum | 21 | 08-07-2006 07:53 PM |
