![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Is there any horrible consequences to running 100% coolant fluid, and not mix it with distilled water?
#2 | |
BTW, I don't know of any dealer or independant garage that actally uses distilled water when replacing antifreez so, the earth will still be in it's orbit if you use clean, plain tap water.
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Uses distilled water, even Culligan's filtered water at times, but getting away from mixing full strength antifreeze and using only premixed now because it's easier. |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
There is no horrible consequence for not adding distilled water to 50% of mix. Water is a better transfer medium for heat energy. Anti-freeze is exactly that, anti-freeze. In winter water will freeze at 32 deg F, anti-freeze prevents freezing well below 0 deg. Running only anti-freeze will reduce the efficiency of your cooling system, especially during summer, because of a lower boiling point.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Coolant Service | N9QGS | DIY / Maintenance / Service | 31 | 11-27-2012 06:55 AM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
| Change Engine Coolant | curtqn | DIY / Maintenance / Service | 34 | 06-25-2009 11:25 AM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
