Old 04-04-2010, 10:55 AM   #11
H3LlIoN
Drives: '09 Yarrrr hatch
Originally Posted by Parmas View Post
Re: Springs, If he said they aren't stock so why on Gude Describtion say:
"7. Valve springs all Gude performance camshafts are designed to operate to extreme rpm on stock valve springs, we spent countless hours designing and developing profile which WILL NOT require a high pressure valve spring which can cause added friction and valve stem failure due to the high loading of stiffer springs vale stem failure will usually cause major engine damage.."
Re: 10Krpm ... I am thinking to build more my motor but I never thought of reving it near 10K neither
Re: Springs...it's a generic package description. Most of his applications he is able to make his cams work with stock springs. He said though that on the 1NZ, the reliability just wasn't there, so they have to be upgraded, but they come with the cam when you purchase it. I don't know what all the fuss is about, his price is right in line with the $700 you guys are talking about spending on those other cams in the performance forum. As of right now, I am planning on just throwing the whole package on there and dyno-ing...if the goods get here and it's relatively easy, I might pull cams out and put them in my factory head and dyno for you guys. Also depends on cost of dyno.
As far as your build, 10k is not unheard of. It's been a while but, if i remember right, the key is a short piston with a long rod/throw. I wouldn't try and boost a 10k motor though, that's more of a N/A endeavor.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Head Liner / Ink removal bikegerm Cosmetic Modifications (Exterior/Interior) 11 06-23-2009 03:56 PM
Fitting amplifier to Yaris head unit nish1979 In Car Entertainment + Electronics (audio / video / alarm) 3 04-08-2009 06:18 AM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
human head in coffee beans wushumasterku Off-topic / Other Cars / Everything else Discussions 8 04-19-2006 11:39 PM
