Old 04-05-2010, 12:32 PM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Maybe some sort of Induced noise from the seats. The back of the seats are metal and your screws drill through them which are touching the amp. That's why they usually tell you to mount your amp to wood. I would start there first see if the Hissing stops. As far as the whining, I'd check your grounds, did you scrape off the paint off all the ground points ? And do you have more than one ground tied to a certain point ?
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
